Stupid Cooling Question, =/ |
Mar 24, 2009 - 4:02 PM |
Enthusiast Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
This may be a dumb question but here goes..I got this "new" car, New to me anyways and I'll drive it for a bit and
i checked the coolant after a 25-30 min drive and the top rad hose will be collapsed.Like someone put a vacuum inside the rad hose and its sucked inwards.I take the rad cap off and air goes in to the radiator and the hose comes back to life. What goin on here...? fyi:This motor is known to have weak water pumps. Might have something to do with it ?? -------------------- |
Mar 24, 2009 - 4:04 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
Is there water in the hoses? it may be low on coolant.
Mar 24, 2009 - 4:51 PM |
Enthusiast Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Are the hoses soft even before reaching normal temps? Could be old hoses.
Mar 24, 2009 - 4:56 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Check your cap.
Mar 24, 2009 - 10:16 PM |
- New Cap
- New Hoses - New Rad - Fresh Coolant -------------------- |
Mar 25, 2009 - 2:09 PM |
is it overheating? mine did that too when it overheated due to a broken headgasket
Mar 25, 2009 - 9:19 PM |
is it overheating? mine did that too when it overheated due to a broken headgasket I sure hope not, Thatd be gay =/ -------------------- |
Mar 25, 2009 - 9:36 PM |
Enthusiast Joined Jan 22, '09 From Bremen Currently Offline Reputation: 2 (100%) |
On my friends car, this happened, but after we replaced the hoses, it was fine.
What kind of car is it? |
Mar 26, 2009 - 12:56 AM |
On my friends car, this happened, but after we replaced the hoses, it was fine. What kind of car is it? Hmm...maybe i'll try that. Its a 99 Maxima -------------------- |
Mar 26, 2009 - 11:31 AM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
This can happen when you replace a bunch of cooling system parts. You may have air trapped in the system. You need to get that air out. Look in the factory shop manual for a procedure to purge the system. If you can't find one, run the car for a while, let it cool down and fill the radiator to the very top. Keep doing this until you can't add any more. Don't worry about overfilling, that's what the overflow bottle is for.
Since you replaced all those parts, presumably for a good reason, I would also replace the thermostat. And make sure the overflow bottle is filled to the correct level and the hose from the overflow bottle to the radiator (or wherever it connects) is not loose, broken or restricted. |
Mar 26, 2009 - 1:01 PM |
This can happen when you replace a bunch of cooling system parts. You may have air trapped in the system. You need to get that air out. Look in the factory shop manual for a procedure to purge the system. If you can't find one, run the car for a while, let it cool down and fill the radiator to the very top. Keep doing this until you can't add any more. Don't worry about overfilling, that's what the overflow bottle is for. Since you replaced all those parts, presumably for a good reason, I would also replace the thermostat. And make sure the overflow bottle is filled to the correct level and the hose from the overflow bottle to the radiator (or wherever it connects) is not loose, broken or restricted. ya it was smashed in the front end..Had to replace everything. But no i didnt replace the t - stat. I'll have to do the fill and run procedure deal too. -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:08 AM |
