n/a power increase, help |
Mar 29, 2009 - 5:17 AM |
Enthusiast Joined Oct 28, '07 From united kingdom Currently Offline Reputation: 0 (0%) |
i have a st202 3sge celica and want to get more power out of it, don't want to turbo the car. it is a 94 model
thinking of piper 285 cams, double valve springs and vernier pulleys along with a superchip icon igntion remap chip, uprated hks head gasket and arp bolts, with an uprated fuel pressure regulator. Looks like it would get me, off there estimates 22bhp. i would like a 4-2-1 manifold but can't find one to suit and i have a knN air filter and mongoose cat back exhaust with a decat pipe. Any suggestions would be great |
Mar 29, 2009 - 7:41 AM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Forgot the SRI or CAI. I had a full exhaust system installed recently including the ebay header (pic in my profile). I thinkl I can feel a slight torque loss but definitely a nice increase in overall hp.
You might want to mill the head for higher comp. and add a better ignition along with plugs, wires and maybe advanced timing. (not really sure if you can do that with our cam design). Why not go with the popular webcams? |
Mar 29, 2009 - 7:48 AM |
forgot to mention i also have a magnecor 8mm ht lead set an brand new ngk spark plugs
what is a SRI and CAI mean sorry to sound dum but not alot available for this car in the uk except from fensport and mine is a 2.0 can't find a header on ebay to match all say st202 3sge 1.8 engine but that engine was on made in a 7afe engine according to all the books that i use in work. |
Mar 29, 2009 - 8:26 AM |
Enthusiast Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
Why dont you just bolt on a turbo kit and run low boost of around 5 - 7 psi. Std manifold and turbo from a ST205 will work well and give you a good power increase.
Mar 29, 2009 - 3:00 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
heres some ideas in this thread
http://www.6gc.net/forums/index.php?showtopic=61995&hl and a HKS part list http://jmjacquemin.celeonet.fr/HKS/Toyota%20Celica.pdf http://www.wheelsjamaicahost.com/wheels_fo...p?topic=33250.0 (you have to scroll down a bit as people, as people learn what a 3rd Gen 3SGE is) -------------------- |
Mar 29, 2009 - 3:09 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
I take it you've stripped all the weight out? That's the best way to make it faster. Take EVERYTHING out.
You'll get small gains from the things you mentioned, but personally i would say it's not worth the money Why not get a GT-4? -------------------- |
Mar 30, 2009 - 8:44 PM |
CAI is a cold air intake and SRI is a short ram intake
Mar 30, 2009 - 11:48 PM |
ITB or cold airbox are the best IMO
Apr 1, 2009 - 3:02 AM |
Enthusiast Joined Mar 29, '09 From HK Currently Offline Reputation: 0 (0%) |
i have a st202 3sge celica and want to get more power out of it, don't want to turbo the car. it is a 94 model thinking of piper 285 cams, double valve springs and vernier pulleys along with a superchip icon igntion remap chip, uprated hks head gasket and arp bolts, with an uprated fuel pressure regulator. Looks like it would get me, off there estimates 22bhp. i would like a 4-2-1 manifold but can't find one to suit and i have a knN air filter and mongoose cat back exhaust with a decat pipe. Any suggestions would be great For your 3SGE ST202, I'll suggest: Tom's Tec II ECU(245PS) Top Fuel intake manifold spacer TRD racing head gasket Denso IK20 Iradium Spark plug Sard adjustable fuel regulator TRD ignition cables HKS cam with adjustable cam pulleys HKS Super Power Flow filter wth intake pipe HKS/FGK/RSR 4-2-1 header pipe HKS Hi-power exhaust pipe Koyo aluminium radiator C-one engine cooling plate Trust oil cooler TRD quick shift set Tom's light flywheel with TRD racing clutch Tanabe stablizer bars(front and rear) TRD/C-one 3pt front strut bar and C-one rear tower bar TRD SUSKIT for CIRCUIT (S.S.S) suspension kit with spring F10 R8 Front 4 pots Rear 2 pots brake kits(swaped from ST205) with Earls brake hoses, TRD/Lockheed AP brake pads |
Apr 1, 2009 - 3:35 AM |
QUOTE Top Fuel intake manifold spacer if im thinking what I think that is, its rubbish someone on youtube got 195BHP with intake and exhaust and adjusted timing from a 3Gen a NZ shop makes 3SGE & 3S-GTE cams etc .. so how about 312dur 12.30 mm lift http://www.camshaftshop.co.nz/index.php/19...l-products.html but you can get some others made, properly want cam springs, but make sure whichever cams you put in, check if any headwork needs to be done to fit them in. other stuff: up the compression 12.0:1, port the head (match porting etc) might want to go colder on the spark plugs as well -------------------- |
Apr 8, 2009 - 2:01 PM |
ITB ? Never heard of that. What is it?
Apr 8, 2009 - 4:00 PM |
Enthusiast Joined Mar 27, '08 From Fort Worth, TX Currently Offline Reputation: 1 (100%) |
Intake Throttle Body
Apr 9, 2009 - 1:56 AM |
Individual Throttle Bodies
Apr 9, 2009 - 3:35 AM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
you can buy trd itb from trd itself.
plain the head for higher comp cams cam gears cold air intake ecu race fuel go 4-1 headers for power best thing to do though is lighten the car. strip out undeeded ****, remove useless brackets, remove air con, cut bolts off that are longer then needed. etc etc -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Lo-Fi Version | Time is now: November 27th, 2024 - 12:21 AM |
