FS: Convertible top parts, Parting out vert TOP ONLY |
Mar 31, 2009 - 11:56 PM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Still have a few parts left. List updated 9/7/2010
All prices are plus actual shipping cost. Headliner $60 Motors $90 ea These are 2000+ Eclipse motors, same as the 6g motors but an improved version. You need to swap connectors. Top latches $45 ea Bows #2 and #3 $60 each Bow #4 (rear bow) $75 Passenger side center rail section $75 Driver side rail complete front to back with all linkages $250 will not separate Boot well $30 local only All parts in nice shape. Dibs will be honored. Local pickup in Detroit area welcome. Note: I don't have any parts for sale other than the convertible top stuff. Sorry, not parting out a car. Just a top. This post has been edited by dgbldr: Sep 7, 2010 - 11:13 AM |
Apr 4, 2009 - 11:36 AM |
Canvas gone.
Bump. |
Apr 5, 2009 - 12:05 AM |
Enthusiast Joined Sep 13, '05 From Kansas Currently Offline Reputation: 9 (100%) |
Apr 13, 2009 - 7:57 PM |
Bump
Apr 26, 2009 - 10:04 PM |
List updated. Bump.
Apr 27, 2009 - 11:43 AM |
Enthusiast Joined Mar 19, '09 From Cleveland Currently Offline Reputation: 1 (100%) |
Is the Boot Well...the actual Boot that you put on when the top is down?
Apr 27, 2009 - 1:12 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I need to fix this:
Do you have what I need? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 27, 2009 - 8:42 PM |
Apr 27, 2009 - 11:27 PM |
May 20, 2009 - 3:24 PM |
Enthusiast Joined Apr 14, '05 From Kilgore, TX Currently Offline Reputation: 0 (0%) |
Do you happen to have rear window switches?
May 21, 2009 - 2:33 AM |
No sorry I don't. You can take yours apart and clean them.
Jun 4, 2009 - 10:48 AM |
Enthusiast Joined May 29, '09 From Lake Ariel, PA Currently Offline Reputation: 4 (100%) |
the motors work fine? if so im interested
-------------------- Representing the Convertible Crew since 2008 |
Jun 5, 2009 - 12:51 PM |
PM sent.
Jun 25, 2009 - 4:58 PM |
Enthusiast Joined Jun 25, '09 From NY Currently Offline Reputation: 0 (0%) |
Do you still have passenger side rail? I am looking for one
Jun 25, 2009 - 10:46 PM |
Passenger side rail I have the middle section and rear pivot bracket (the one the motor mounts to). Front and rear sections of rail are sold.
Driver side I still have all sections. |
Jun 26, 2009 - 11:41 AM |
Enthusiast Joined Jun 26, '09 From Maryland (DC Suburbs) Currently Offline Reputation: 0 (0%) |
Hi - I'm also looking for part of the passenger side rail. Below I've included picture of the part that's broken. The rail has literally broken into two pieces; it's worse than it looks in the picture.
Do you still have this part? If so I'd like to buy it. (I think may have happened when the driver side convertible motor failed. Have other folks had this problem -- one motor fails, and the frame on the opposite side snaps from the extra/uneven weight?) Thanks ... |
Jun 27, 2009 - 1:35 AM |
Sorry, no, that section is sold. Same one neko9999 needs.
Yes, it's common for rails to break when one motor stops working. When that happens you need to stop using the motors and put it up and down by hand. When only one motor works, it puts a severe off-center load on the top frame and can break rails. |
Jun 27, 2009 - 11:48 AM |
Thanks dgbldr.
I know this is getting OT, but how can you tell when one motor stops working? My top seemed to be going up and down just fine and then ... snap. I can't tell by the sound unless I stand outside the car while someone else operates the up/down button. Sounds like maybe there'd be a good market for a simple LED hookup to warn when one motor gives out, or better still, a relay to stop both motors when either one doesn't work. Yes, it's common for rails to break when one motor stops working. When that happens you need to stop using the motors and put it up and down by hand. When only one motor works, it puts a severe off-center load on the top frame and can break rails. |
Jun 27, 2009 - 10:17 PM |
It's not really obvious when one motor stops pulling. Some people have a better feel than others. Sound, feel, subtle hints.
If you can design and build a "simple LED hookup" to detect a motor not lifting, I'm ready to buy |
Jul 2, 2009 - 2:56 PM |
what are you going to do with the car...
does this vert have a center stoplight that works? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: November 27th, 2024 - 9:46 AM |
