> Carpet Removal, dead pedal removal
post Apr 1, 2009 - 1:19 PM
chaynes
Joined Jun 8, '08
From LR, AR
Hey guys, I need to remove the dead pedal so I can take my nasty carpet out and give it a thorough cleaning! What is the best way to get it out of there? Does it just snap in/out? I wouldn't want to break it...
Thanks!
1995 Celica ST
Parts needed: 2x 14" steel rims
Washer fluid resevoi
post Apr 1, 2009 - 2:24 PM
if you look carefully it has two circles in the middle.
those are actually screws. they come off easy, dont try to pop it out or it will break
post Apr 1, 2009 - 3:17 PM
chaynes
Joined Jun 8, '08
From LR, AR
QUOTE (njccmd2002 @ Apr 1, 2009 - 3:24 PM) *
Tricky Tricky! I saw those but thought they were just molded in like that....
You rock, Thanks!
1995 Celica ST
post Apr 14, 2009 - 12:45 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
If you use a small flathead and pull it out, it will come out perfectly fine. I have redone my carpet and pulling it straight out will not break anything. Its a socket suction cup that will pull right out with force.
Lo-Fi Version Time is now: November 23rd, 2024 - 6:52 AM
