> Interior neon wired to a switch, Need some help
post Apr 4, 2009 - 3:01 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Alright so i used teh search and looked through all the pages that came up and nothing really helped me. I have Neons in my interior that i want to wire to a switch with an indicator light. I have the neons running off the cigarette lighter and are working fine. I tried wiring them to a switch cause i thought i knew what i was doing but had no luck so i am coming to you guys. I have a toggle switch i want to wire it to. The back has 3 prongs one for power one for acc and one for ground. If someone could give me a hand and tell me how to wire these things up that would be great. Any help is appreciated.
Thanks
My Celica!
post Apr 4, 2009 - 4:43 PM
korban
Joined Feb 5, '09
From New Zealand
Your neon should have 2 wires, one red, one black. If you cut these then you have 2 wires from the cig lighter plug, and 2 going to your light. Attach both black wires to the ground on the switch. Attach the red wire from the cig plug to the 'power' terminal on your switch, and the red wire from the light to the 'acc'. All done.
post Apr 4, 2009 - 10:51 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Thanks a lot Ill try that out tomorrow.
My Celica!
post Jan 12, 2010 - 6:48 PM
zfjohnson07
Joined Apr 11, '09
i did something like this guy got a little led light that i wired to the cigaratte wires, well i was trying to put a on/off switch into it and it has 2 wires, and well everytime i keep trying to wire them the fuse blows up i thought myabe i needed a more powerful fuse so i put a 30 in the cigaratte/ radio fuse holder, any one got some pointers how to do this correct?
Lo-Fi Version Time is now: January 14th, 2025 - 7:41 AM
