> changing head light, has anybody done it
post Oct 14, 2003 - 1:22 AM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
Hi,
I am looking to replace my stock Low Beam 9006 bulbs.
Has anybody done this. Are there instructions on how to replace them.
How do i take the head lights off.
Is there a writeup on this procedure.
Thanks,
PReetham.
post Oct 14, 2003 - 1:56 AM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (kingpreetham @ Oct 13, 2003 - 11:22 PM)
Hi,
Thanks,
PReetham.
If you're just replacing the bulbs... then just grab the socket, twist, and it should come out. The bulb just plugs in, sorta. Pull out the bulb, replace, and reverse procedure. Just follow the basic headlight bulbs replacement rules...don't touch the bulb... ;]
post Oct 14, 2003 - 2:06 AM
Also, be sure to upgrade your wiring to 12 gauge wiring if you're going to be running bulbs that run at a higher wattage than stock.
post Oct 14, 2003 - 5:49 AM
macavely
Joined Nov 4, '02
yea if your just replacing your OEM bulbs with another pair just twist and pull they have pictures in your owners manuel....
post Oct 14, 2003 - 11:31 AM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
QUOTE (Coomer @ Oct 14, 2003 - 12:06 AM)
i am running that same wattage as the stock....i guess i need not change the wiring.
My concern is about opening up the light assembly to reach the bulb...do ineed to take my bumper off..or can i get to it from under the hood...
post Oct 14, 2003 - 6:25 PM
phat94celi
Joined Oct 9, '02
From Longmont, CO
You need to open your hood. Then, on the back of the headlight assembly, there is a socket with wires running to it. Simply twist that, then pull it out. The bulb plugs into that socket. Pull the old bulb out, push the new bulb into the socket. Place the socket back into the back of the headlight and twist it to lock it.
Make sure you dont touch the glass part of the bulb.
-Kaleb
post Oct 15, 2003 - 2:19 AM
soldier4life
Joined May 1, '03
From san diego, california
QUOTE (kingpreetham @ Oct 14, 2003 - 9:31 AM)
you dont need to take the bumper off or the head light out...just open your hood and follow the steps that the other guys gave u
post Oct 21, 2003 - 2:43 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
yeh its under the hood, in the back of each light.
Lo-Fi Version Time is now: November 25th, 2024 - 4:22 AM
