> 95.5 7afe or 94?, what if anything to swap over
post Apr 8, 2009 - 1:32 PM
southwest2118
Joined Jan 13, '06
i have a 95.5 7afe(obd2[not really]) with crank sensor, has EGR, and non-adjustable distributor. with a blown engine.
i got a 94 7afe(obd1) with no crank sensor, no EGR, and adjustable distributor for free that i want to put in my 95.
i plan on turboing the obd1 engine as the obd2 was turboed.
question :
1.would you leave everything in tacked and just do a swap?
2.should convert this obd1 to egr .
3. if i want to put the crank pos sensor in it i will need to change out the oil pump i believe which i dont want to but will it be worth it?
4. can put the crank sensor with adjustable distributor?(but if i do that the obd2 pcm will try to adjust my timming).
more info: turbo fuel adjustments will be made adjusting map sensor signals(SAFC type of piggyback)
post Apr 8, 2009 - 7:29 PM
QUOTE (southwest2118 @ Apr 8, 2009 - 1:32 PM) *
question :
you'd need to swap the oil pump, and crank gear as well, (it has the trigger wheel built into it) onto the older motor, as well as your distributor ect.
post Apr 8, 2009 - 11:38 PM
southwest2118
Joined Jan 13, '06
QUOTE (presure2 @ Apr 8, 2009 - 7:29 PM) *
question :
would it be better to turbo the 94 motor? thinking about swaping motor trans w/ pcm and calling it a day
Lo-Fi Version Time is now: November 23rd, 2024 - 2:01 PM
