> Brand New 4AGE 20v Wiring Harnesses
post Apr 9, 2009 - 8:14 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
As some of you know we've been working on building 100% new wiring harnesses from scratch using all new OEM connectors, wire seals, terminals, and wire. Here are some pictures of a nearly complete 4AGE blacktop harness. This harness is what we consider to be a "bare bones" wiring harness meaning that you could use it install a 20v into basically any vehicle. We can even add in the relays, fuse holders, etc to make it completely self-contained. This particular harness was tailored to an AE86 GTS swap, for example the wires for connection to the chassis were located in the area needed, and the igniter and coil plugs have been relocated to work with a distributor relocation kit.
The price on these new harnesses has not been set in stone yet, but we should have those numbers figured out pretty soon. We charged only $350 for this particular one. If the customer had supplied us with their GTS harness we could have wired it up plug and play for an additional charge. I think that this will be an excellent option for people with engines that have no harness, or a cut/damaged harness, or simply want everything to be brand new.
Shielded cable is used for the 02 signal wire, knock sensor wire, and of course the distributor. The shielding is connected to ground, this absorbs electromagnetic interference of the low-volt signal wires.
Normally I would loom this up with all new looming and make it look almost like factory. Per the customer's request we left it unloomed.
Click here to see my swaps
drtweak@phoenixtuning.com
post Apr 9, 2009 - 8:22 PM
Thats pimp. I like it a lot.
post Apr 9, 2009 - 9:30 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
$350 is a steal, having done just wiring repair and repinning a few connectors it's a real pain. granted you're not working with 4 inches of wire upside down under the dash of a car, but its still a tedious job.
post Apr 9, 2009 - 10:11 PM
Muggs
Joined Sep 13, '06
From St. paul, MN
Quality work, as usual!
I am sooo glad we have this man in the toyota community.
post Apr 10, 2009 - 4:27 AM
thats some good stuff right there tweak.
post Apr 10, 2009 - 10:55 AM
Dr_Tweak
Joined Mar 31, '04
-Doc
post Apr 10, 2009 - 11:22 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Beautiful work.
post Apr 10, 2009 - 12:14 PM
Fate
Joined Nov 30, '04
From Atlantic City
wow, great job tweak.
post Apr 10, 2009 - 12:22 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I love it Doc, You will be getting my service soon this summer.
94 Celica gt white (sold)
post Apr 10, 2009 - 1:58 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Looks great. Customer is probably going to tuck the wires and get the routing sorted before looming...
One of these days I'll be back behind the wheel of a 20V.
Dr. Tweak, you should really get into the VW community. God knows oem wiring was terrible on those things.
**** Photobucket
post Apr 10, 2009 - 9:16 PM
Zeros2
Joined Sep 25, '08
From colorado
nice so are you going to make these instead of the rewiring of the harness gig? if so how much for a brand new one of these for a 97 celica st on a 4age silvertop
post Apr 21, 2009 - 11:46 AM
phantom
Joined Oct 1, '07
From Georgia
I have the Same question /\ /\ /\ /\ /\ /\ /\ /\ /\
post Apr 21, 2009 - 8:58 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Hey sup Dr. Tweak, long time no see smile.gif Anyways, by chance are you able to make a conversion harness for the ST m/t connectors to mate up to the BT ecu? And also, are you able to make one for the AFM to the Blacktop AIT and Map sensor? Basically I'd want to convert the ST to run off of the blacktop electronics but still retain the conversion that you made for me before. Let me know if it's possible and how much it will cost. Thinking about getting it before the end of the year cause I'm getting deployed again. Thanks.
post Apr 21, 2009 - 10:09 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
thats some beautiful work! ill be looking for your services prob. sometime later this year. thumbsup.gif
Lift Addict!! ^_^
post Apr 22, 2009 - 8:37 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE (Zeros2 @ Apr 10, 2009 - 10:16 PM) *
It's an option, though rewiring of the harness will probably still be our primary method. Building new harnesses from scratch like this is quite expensive.
For that conversion, I would purchase a complete Celica ST harness, and then rewire it but using new terminals and connectors like you see above. I could do the whole job for $550 - $600 (you wouldn't have to provide anything).
QUOTE (netrata @ Apr 21, 2009 - 9:58 PM) *
I do have patch/conversion harnesses like what you're describing for the ECU side, they are around $180 or so (I have to check exactly). However on the engine harness side it's a little more tricky, you would probably have to wire in the MAP and IAT. I will look into it for you though.
-Doc
post Apr 22, 2009 - 3:52 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
post Jul 14, 2012 - 10:23 PM
sslinkyy
Joined Jul 14, '12
From Quincy, ca
I have an 92/93 Celica that originally came with a 4afe, but have swapped in a 4age. I am looking to purchase a "bare bones" harness. Is this harness still in production?
post Jul 16, 2012 - 9:10 AM
PhoenixTech
Joined Dec 3, '08
QUOTE (sslinkyy @ Jul 14, 2012 - 10:23 PM) *
Yes, we are still making these harnesses. The "bare bones" harness is more of a self contained unit and would require some wiring on your part once you get the harness back. We can make this brand new 20V harness plug and play into a Celica no problem!!
www.tweakdperformance.com
sales@tweakdperformance.com
Lo-Fi Version Time is now: December 29th, 2024 - 12:32 PM
