switching 94 gt to a 2000s gts motor |
Apr 11, 2009 - 8:59 AM |
Enthusiast Joined Sep 29, '08 From Ky Currently Offline Reputation: 1 (100%) |
Will this work? Sensors, tranny, etc..
I found a guy who loves to do mods. He said if I get the motor, he'll do the work free; simply spread the word about him. Is it going to cost a lot in conversions? I need to do something. I threw a rod racing at 120. I miss my car reaallll bad. If this won't work, does anybody know where to find a cheap motor or rebuild kit? Thanks, peace out |
Apr 11, 2009 - 11:11 AM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
Will this work? Sensors, tranny, etc.. I found a guy who loves to do mods. He said if I get the motor, he'll do the work free; simply spread the word about him. Is it going to cost a lot in conversions? I need to do something. I threw a rod racing at 120. I miss my car reaallll bad. If this won't work, does anybody know where to find a cheap motor or rebuild kit? Thanks, peace out it is deff. possible, you biggest issues will be fabin a header, and getting an emanage, or hydro to tune the engine, and its gonna be a wiring nightmare, plus the fact that the 2zz engine even from a junk yard is atleast $2000 plus the c60 transmission. it will be expensive and time consuming, but if u got the $$$ go for it. -------------------- Lift Addict!! ^_^
Apr 11, 2009 - 4:23 PM |
Will this work? Sensors, tranny, etc.. I found a guy who loves to do mods. He said if I get the motor, he'll do the work free; simply spread the word about him. Is it going to cost a lot in conversions? I need to do something. I threw a rod racing at 120. I miss my car reaallll bad. If this won't work, does anybody know where to find a cheap motor or rebuild kit? Thanks, peace out Serves you right for street racing. At the top of the forum there is a thread called "Engine FAQ, swaps, intakes, exhaust,ect, READ THIS FIRST BEFORE POSTING" in that there is this thread: Pay close attention to the second paragraph under non-feasible. http://www.6gc.net/forums/index.php?showtopic=1311 This post has been edited by 95CelicaST: Apr 11, 2009 - 4:25 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 17, 2009 - 5:36 PM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
^^Harsh^^
but very true. if you got the time and money go for it but the 2ZZ was never designed for our cars. not to mention your down-sizing your engine from a 2.2L to a 1.8L so that alone would be a deterrent to most. Simply put its going to cost ALOT! its definitely not going to be reliable. and its going to suck as a daily driver. nuff said |
Apr 17, 2009 - 5:40 PM |
downsizing from a 2.2 to a 1.8 isn't the problem here. It's not about displacement, it's about compression. But it's a moot point since it's not a likely swap. I guess anything is possible, but what if the mechanic gets halfway through and says oh sh1t, I can't do this, and throws in the towel since he's doing it for free anyway?
You wanna do a less common swap, do a 6 cylinder swap. -------------------- |
Apr 17, 2009 - 6:06 PM |
downsizing from a 2.2 to a 1.8 isn't the problem here. It's not about displacement, it's about compression. But it's a moot point since it's not a likely swap. I guess anything is possible, but what if the mechanic gets halfway through and says oh sh1t, I can't do this, and throws in the towel since he's doing it for free anyway? You wanna do a less common swap, do a 6 cylinder swap. well it depends honestly on wat your looking for. an ST's 7A is also a 1.8L but its designed vastly different. so unless you plan to drive over 5000 rpms just to get decent torque figures the 2ZZ isnt a great choice unless you plan on applying force induction. And parts alone are going to be expensive you might as well get a complete GTS even if he does it for free. |
Apr 17, 2009 - 7:15 PM |
downsizing from a 2.2 to a 1.8 isn't the problem here. It's not about displacement, it's about compression. But it's a moot point since it's not a likely swap. I guess anything is possible, but what if the mechanic gets halfway through and says oh sh1t, I can't do this, and throws in the towel since he's doing it for free anyway? You wanna do a less common swap, do a 6 cylinder swap. well it depends honestly on wat your looking for. an ST's 7A is also a 1.8L but its designed vastly different. so unless you plan to drive over 5000 rpms just to get decent torque figures the 2ZZ isnt a great choice unless you plan on applying force induction. And parts alone are going to be expensive you might as well get a complete GTS even if he does it for free. this is not true with the 2zz other than it is expensive, it gets its maximum torque before 4k rpm, it is gutless from then on till lift at 6800 rpm, its great off the line, and in the top end, especially if u get a cable throttle body that came in the matrix and corrola xrs's, instead of the drive by wire crap that came in the gts's. -------------------- Lift Addict!! ^_^
Apr 17, 2009 - 10:17 PM |
Enthusiast Joined Mar 27, '08 From Fort Worth, TX Currently Offline Reputation: 1 (100%) |
this is not a wise decision...
Fabbing motor mounts, wiring, sourcing, and any bumps on the road is gonna take much MUCH longer. -------------------- |
Apr 17, 2009 - 10:19 PM |
i think you might be able to pull off better with tags and title to just by a 7th gen. they are cheap now days,
Apr 18, 2009 - 2:16 AM |
i think you might be able to pull off better with tags and title to just by a 7th gen. they are cheap now days, That is a real nice thought. But parents don't have the money, my job shut down a few paychecks after I started, and I don't have a way to get to a job anymore because I have that crazy overprotectve mother who thinks its dangerous to walk in my tiny town. MY celi cost my dad $1650 wrecked, <$2000 when everything was done. Love my little car. |
Apr 18, 2009 - 9:52 AM |
yeah but just the engine with swap is around 7k, so your best bet is to find used engine from somebody that swapped.
Apr 18, 2009 - 11:21 AM |
If you had an ST it would be cheaper to step up to a better motor, but a 3SGTE will cost you a couple grand, then wiring, exhaust, random bugs with every swap, etc. It is a general rule of thumb to have about 6 grand set aside to cover all your costs with a 3SGTE. Since a 2ZZ swap hasn't ever been done into a 6th gen celica it is going to cost A LOT more. Plus I'm sure since your riding mom and dad's pocketbook nothing will fly but another 5SFE.
But if you're serious about it why don't you PM Dr. Tweak and ask what it would cost. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 18, 2009 - 1:14 PM |
If you had an ST it would be cheaper to step up to a better motor, but a 3SGTE will cost you a couple grand, then wiring, exhaust, random bugs with every swap, etc. It is a general rule of thumb to have about 6 grand set aside to cover all your costs with a 3SGTE. Since a 2ZZ swap hasn't ever been done into a 6th gen celica it is going to cost A LOT more. Plus I'm sure since your riding mom and dad's pocketbook nothing will fly but another 5SFE. But if you're serious about it why don't you PM Dr. Tweak and ask what it would cost. X2 -------------------- Lift Addict!! ^_^
Apr 19, 2009 - 9:45 AM |
If you had an ST it would be cheaper to step up to a better motor, but a 3SGTE will cost you a couple grand, then wiring, exhaust, random bugs with every swap, etc. It is a general rule of thumb to have about 6 grand set aside to cover all your costs with a 3SGTE. Since a 2ZZ swap hasn't ever been done into a 6th gen celica it is going to cost A LOT more. Plus I'm sure since your riding mom and dad's pocketbook nothing will fly but another 5SFE. But if you're serious about it why don't you PM Dr. Tweak and ask what it would cost. X2 well i'm starting to wonder if this motors gonna be hot or something cuz he told me to do it all for $1500... |
Apr 19, 2009 - 10:03 AM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Why are you relying on mommy and daddy's money? If you were to spend your own money you would take better care of the motor in the first place rather than racing around town blowing up your motor. The motor isn't a performance motor.. I owned a 7th gen gts and it was a blast to drive. Well the first couple of weeks. After that its just plain jane boring. You want fun day in and day out get a 3sgte under the hood. And use your own money. You'd appreciate it more.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Apr 20, 2009 - 11:44 AM |
the 2ZZ makes more HP than the 5S and weighs half as much so it would be an upgrade, but the major issue will be motor mounts and the fact that the egine is backwards. the intake and exhaust are on opposite sides.
Apr 20, 2009 - 5:05 PM |
Why are you relying on mommy and daddy's money? If you were to spend your own money you would take better care of the motor in the first place rather than racing around town blowing up your motor. The motor isn't a performance motor.. I owned a 7th gen gts and it was a blast to drive. Well the first couple of weeks. After that its just plain jane boring. You want fun day in and day out get a 3sgte under the hood. And use your own money. You'd appreciate it more. Mom's crazy overprotective. She "lost" my birth certificate so I couldn't get my permit. Finally convinced her to let me get a job; they closed after 3 paychecks. So, I have no money, no job, and now no ride to get to a job if one of the freaking 100 places I put in an application at ever calls. And dad told me if I kept good grades and stayed outta trouble, he'd get me a car. I had a $2000 budget for my 3.7 gpa. So I don't exactly feel spoiled or anything here... But yea, I was dumb for racing it. |
Apr 20, 2009 - 5:09 PM |
Wow!! I didn't get squat for my 3.7 GPA in HS.. I was also all-conference in football... But good for you. To save yourself money use that $2000 and get a 98+ 5s motor.. Then when you get power hungry BOOST it.
Apr 20, 2009 - 9:34 PM |
Wow!! I didn't get squat for my 3.7 GPA in HS.. I was also all-conference in football... But good for you. To save yourself money use that $2000 and get a 98+ 5s motor.. Then when you get power hungry BOOST it. X2!!! much cheaper, and a much bigger gain than just swapping in a stock 2zz -------------------- Lift Addict!! ^_^
Apr 21, 2009 - 9:57 AM |
anything is possible, its just not worth the power in return for the hard labor of that motor.
This post has been edited by trdproven: Apr 21, 2009 - 9:57 AM -------------------- 94 Celica GT
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:03 AM |
