Will these rims fit? |
Apr 12, 2009 - 11:00 AM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I found these rims on ebay and wondering if they will fit my car:
http://cgi.ebay.ca/18-motegi-hyperblack-sp...A1%7C240%3A1318 Here are the specs: Size 18 x 8 Offset 40 Part Number 2747-8817 Hub Bore 72.6 Bolt Pattern 5x100 Also, what would be the best trie size to fit my 95 hatchback. It still is on stock suspension, so it is not lowered or anything. Thanks a lot -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Apr 12, 2009 - 12:05 PM |
Enthusiast Joined Oct 2, '07 From Manitoba, Canada Currently Offline Reputation: 6 (100%) |
ya man they'll fit and you'll want 225/40/18s
Apr 14, 2009 - 1:11 PM |
That's the right offset for a hatchback?
Apr 14, 2009 - 1:19 PM |
Enthusiast Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
Apr 14, 2009 - 5:44 PM |
i dont recall stock hub size, but you might want to look into hubcentric rings to match the wheel hub size to the one on the car.
For example, stock hub size of my wrx is 56.1. I bought wheels with a hub size of 73. I bought hubcentric rings that fit in the wheel and brought the center hub down to 56.1 so that I dont get any strange vibrations. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 14, 2009 - 7:17 PM |
So what is the difference if i use hubcentric rings? I'm kinda new to this and I'm just to learn as much as possible.
Apr 14, 2009 - 8:27 PM |
If the wheel's center is larger in diameter than the hub on the car you will get vibrations while driving. With the rings it'll bring down the wheel's center to match the hub and rid you of vibrations.
Lo-Fi Version | Time is now: December 4th, 2024 - 12:58 PM |
