Vert quarter window removal, Anyone have a how-to? |
Apr 12, 2009 - 12:34 PM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
If anyone has removed the quarter window glass on a convertible, I'd appreciate some hints.
Can't quite figure out how to disconnect the glass from the motor arm. The factory manual shows a pin with a simple simple hairclip/cotterpin that you remove to disconnect. They must have made changes after the manual was published, because that's not what I have on the car. It's a bolt with a coil spring over it. The head of the bolt is not accessible. |
Apr 17, 2009 - 12:22 AM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
If anyone has removed the quarter window glass on a convertible, I'd appreciate some hints. Can't quite figure out how to disconnect the glass from the motor arm. The factory manual shows a pin with a simple simple hairclip/cotterpin that you remove to disconnect. They must have made changes after the manual was published, because that's not what I have on the car. It's a bolt with a coil spring over it. The head of the bolt is not accessible. |
Apr 17, 2009 - 1:48 AM |
Enthusiast Joined Sep 29, '06 From US Currently Offline Reputation: 3 (100%) |
Just take the whole assembly out, (regulator, motor) I believe its 5 or 6 nuts for both; then you can detach the window from the motor. If you have any more ??s pm me.
Apr 17, 2009 - 11:10 AM |
Thanks RisingSun1. I'll try that.
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:58 PM |
