> Lots 'O Water on my carpets, help
post Apr 12, 2009 - 2:14 PM
circuscatch85
Joined Jun 14, '08
From Waldoboro, Maine
I've had a leakage problem for quite a while not, but i'm finally deciding to try and fix it. The water only appears on the passenger side of my car (front and back). My sunroof is not leaking, i've checked the tubes and everything. I went out this morning and i literally had free standing water in the back passenger side carpet. Has anyone had any problems like this and know how to fix it? any help would be very much appreciated
post Apr 12, 2009 - 4:06 PM
Legit94GT
Joined Feb 6, '08
From Oregon
It COULD be a problem with your a/c drain tube. Mine was really clogged and instead of the condensated water dripping off through the drain tube it would slosh out on both sides of the car if i took a corner a bit too fast... But yours would have to be totally bocked and only comign out when you make alot of hard left turns. ALOT of turns to get standing water way in the back...
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Apr 12, 2009 - 9:35 PM
circuscatch85
Joined Jun 14, '08
QUOTE (Legit94GT @ Apr 12, 2009 - 4:06 PM) *
thanks for the idea, but i get the water even when i haven't driven my car for a month while i'm away at school
post Apr 12, 2009 - 11:44 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
if you have a hatch... mine would leak in the back... there are two rubber stops on both sides of the hatch and one had a broken bolt and an empty hole.... water travels right down the path and through the hole... into the wheel well and down the back seats (which are lower than the hatch) onto the ground... check all the hatch glass and any holes... also check around were the windows meet the metal... that rubber had been known to go bad
Breaking Axles...
post Apr 14, 2009 - 9:35 AM
SoundSlut_dotcom
Joined Feb 16, '03
QUOTE (circuscatch85 @ Apr 12, 2009 - 1:14 PM) *
my sunroof gets clogged alot
post Apr 14, 2009 - 10:41 AM
circuscatch85
Joined Jun 14, '08
QUOTE (pittfirefighter @ Apr 13, 2009 - 12:44 AM) *
Would it leak even if I hadn't opened my hatch in a long time? I was away at school and hadnt even touched the car in a month and the first time i opened it there was water soaking the carpets.
Lo-Fi Version Time is now: January 10th, 2025 - 8:06 AM
