removing alternator fuse |
Apr 15, 2009 - 5:51 PM |
Enthusiast Joined Feb 9, '09 From Toronto Currently Offline Reputation: 2 (100%) |
anyone know how to remove the alternator fuse???
Apr 15, 2009 - 6:22 PM |
Enthusiast Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Got this Chilton repair manual yesterday--I'm looking to see if it says anything about it.
Apr 15, 2009 - 6:24 PM |
I think there are little screws that hold it in place that you have to remove in order to get the fuse out.
Apr 15, 2009 - 6:44 PM |
No listing--sorry
This post has been edited by Bigblock: Apr 15, 2009 - 6:46 PM |
Apr 15, 2009 - 7:28 PM |
figured it out after about an hour and a half haha. you have to remove the whole fuse unit.. there are two clips and the black covering comes off. then u have to remove the yellow casing which the fuses sit in.. you gotta go under it and there are 4 small clips u use a flat head screw driver. the yellow casing just slides right out. then the alternator fuse has two ground wires on both sides with philips screws. unscrew those and wallah! and by the way u dont have to remove any fuse links
Lo-Fi Version | Time is now: January 10th, 2025 - 3:23 PM |
