Delete*** |
Delete*** |
Apr 18, 2009 - 12:01 PM |
Enthusiast Joined Feb 19, '08 From Elk Grove/South Sac Currently Offline Reputation: 0 (0%) |
last weekend i heard a grinding noise on my left front side wheel well and i figured it was my hub so i just replace the whole knuckle and since i was down there anyways i replace the front rotors with oem replacements and new pads also. but on monday coming back home from school after about 20 miles i tried to brake and the petal went flat and i had no braking power at all (yes i bleed my brakes and new brake fluid also) so i quickly downshift and used my ebrake to stop pulled over and towed my car home. im not sure what caused it and i still do not have braking power cars just been sitting in the garage could it be the master cylinder or the brake booster?
This post has been edited by GoToSleep: Apr 20, 2009 - 9:26 PM |
Apr 20, 2009 - 10:43 AM |
You checked your brake fluids to see if you had any left? Could be the cause of a line leaking.
Apr 20, 2009 - 6:47 PM |
yeah fluids full everything in good shape masters good and so is the brake booster what happen was the left half shaft(axle) snapped in two which made the caliper bracket slip out onto my new rotor messing everything up including the left knuckle setup
Lo-Fi Version | Time is now: November 25th, 2024 - 8:58 PM |
