> cleaned my throttle body today now have a few questions
post Apr 20, 2009 - 5:15 PM
chandy1986
Joined Mar 23, '06
From Mass
I have two questions today. I took my throttle body off and cleaned it. When i took it off i was a bit surprised by what i saw. I saw that the intake manifold was black on the inside with what would appear to be dirt and grime or something that looked like that. my question is the 7afe suppose to be like that or not? when i looked at the throttle body one side was dirty and the other side was how i expected to find it.
My other question that when cleaning the throttle body, the spring that makes the throttle plate reclose I took it off. When i started driving the car like that cuz i forgot to but it back on, I noticed that the car accelerated faster than it normally does. I think it is cuz when i moved that spring position lower it puts less tension on the spring so it can open and close faster. But I wanted to know if I drive it like that will i damage anything?
This post has been edited by chandy1986: Apr 21, 2009 - 1:15 PM
post Apr 20, 2009 - 5:36 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
The PCV and the valve cover breather hose do dump back into the intake and they can carry with them oil and whatnot, causing your intake plenum to get all drity and grimy. I cleaned mine recently and it was also quite black on the inside.
post Apr 20, 2009 - 7:08 PM
chandy1986
Joined Mar 23, '06
From Mass
ah so thats why its so black in there. I always wondered wat the purpose of the pcv. i changed it last year just for the sake of changing it.
wat about my second question? say if i leave that spring like that will i be damaging anything? it made my celica feel torquey xD
edit: if the oil and junk goes back into the intake wont i be getting oil into the cylinders or no? or does it get sucked out somewhere in the intake manifold?
This post has been edited by chandy1986: Apr 20, 2009 - 7:50 PM
post Apr 20, 2009 - 7:19 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
mmm interesting! i'll look forward into this
post Apr 20, 2009 - 7:34 PM
Sinyk
Joined Oct 4, '06
Um, I'm not sure. My concern would be if it didn't close all the way or properly, it could probably throw off your AFR and cause your car to run rough.
This post has been edited by Sinyk: Apr 20, 2009 - 7:34 PM
post Apr 20, 2009 - 8:39 PM
chandy1986
Joined Mar 23, '06
From Mass
yea u might be right about it throwing a code but my car already idles rough. thats why i was cleaning my TB. hoping to fix that problem cuz when my car is cold idle is fine but when the car is warm it tends to idle rough.
Lo-Fi Version Time is now: November 28th, 2024 - 12:23 AM
