> Removing the AT Shift Lever?
post Apr 20, 2009 - 8:11 PM
solidxsnake
Joined Apr 20, '09
Recently the gear light went out in my '95 Celica ST Liftback (got it free as my first car as my brother just bought himself a new car). I pulled out the center console from trial-and-error and eventually got the bulb replaced and such... However, I had to work around getting the shift-lever out to get the cover under the trim (where the cigarette lighter mounts). I see that there's two screws on the front of the shift-lever, and taking those out loosens the lever, but it doesn't go anywhere from there...
I feel like it's something so very simple, but I can't figure it out. I have the Haynes service manual but that's no help.
Any help?
First post smile.gif I'm gonna end up replacing the interior dash lights to red lights, that would look awesome IMO. As for performance mods.. I don't plan on doing too much in that regard. I use the car to get back and forth and such and I don't really have the money to improve a fairly weak engine, especially with an AT =_=
This post has been edited by solidxsnake: Apr 20, 2009 - 8:11 PM
~Moving on to a 2002 Corolla S~
R.I.P Tom Celica - 1994-2010
post Apr 20, 2009 - 11:52 PM
Akirad1
Joined Jun 2, '08
From Fort Worth, Texas
well ill be the first to welcome you but as to answer your ? i dunno never tried to remove my shifter
post Apr 22, 2009 - 7:25 PM
solidxsnake
Joined Apr 20, '09
Bump (not sure if that's allowed on this forum, but I did see it earlier. If not, won't happen again. Didn't see a mention in the rules.)
post Apr 23, 2009 - 9:35 AM
Muggs
Joined Sep 13, '06
From St. paul, MN
I think the wires for the O/D button are holding it in. If you can locate and disconnect them, it should pull right out.
post Apr 23, 2009 - 11:35 AM
solidxsnake
Joined Apr 20, '09
post Dec 10, 2012 - 10:31 AM
FrankB2
Joined Oct 25, '12
From Pennsylvania
Old thread, but did you ever figure this out?
post Dec 10, 2012 - 10:33 AM
solidxsnake
Joined Apr 20, '09
I did eventually get the bulb replaced, but I didn't actually get the shifter removed, just loose enough for me to jam my hands under and replace the bulb. The wires for the O/D button are what keep the shifter held into the console, if you can remove them (or cut them), the shifter should slide right out.
post Dec 10, 2012 - 10:42 AM
FrankB2
Joined Oct 25, '12
From Pennsylvania
Bummer..... I have to replace the slide cover, and thought the OD wiring might be a problem. Thanks!
Lo-Fi Version Time is now: January 9th, 2025 - 4:58 PM
