2 Pages V  < 1 2
> GT-four hood center grill, what happen if......?
post Feb 4, 2005 - 11:24 PM
Jaemus
Joined Feb 4, '05
From Sydney, Australia
on my car, underneath the bonnet is covered with insulation, and there is a plastic sheild that is in between the vent and the insulation but set forward slightly, so what happens is, if any water drips on the insulation and doesnt get absorbed or evaporated straight away, it just runs off onto the plastic sheild, which channels all the water to the front of the hood and it runs out down near the radiator.
not to mention, it keeps the engine clean from dust and dirt and anything else that could fall through an open vent. it still vents heat with the insulation in place, but most of it is vented out of the rear vents.
post Feb 5, 2005 - 12:24 AM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
how do you people keep your engine bays clean if you are scared of getting your engine wet?
i hit mine up with a pressure washer and it doesnt do any harm. water doesnt hurt the outside of and engine
post Feb 7, 2005 - 4:13 PM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
Why don't you make a "catchcan" sort of thing underneath the scoop with a little hose running downwards to the ground. That way your valvecover won't get corroded.
edit: same as two posts above, I can't read smile.gif
This post has been edited by Silvan: Feb 7, 2005 - 4:17 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 28th, 2024 - 4:52 AM
