Enthusiast ![]() Joined Sep 15, '08 Currently Offline Reputation: 0 (0%) ![]() |
so my motor swap is underway(4AGE silvertop). i want to boost it but how much boost can that motor take? i know that the compression is high but what will it handle?
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) ![]() |
Not much, I would think that even 6 psi or so would be pushing it. Any more and you'll need to start thinking about water injection , higher octane fuel and such. Those motor's aren't really designed to be turbo'd or force inducted, they're designed for NA power hence the high compression.
-------------------- AIM : FAQdaWorld
Enthusiast ![]() ![]() Joined May 14, '08 From Grand Island NY Currently Offline Reputation: 18 (95%) ![]() |
6 psi was the max I could get, but with aem methanol injection and cam gears I was able to get it up to 10psi without knocking. If you need any help let me know.
-------------------- ![]() 1994 Supra TT 1999 Cadillac Escalade (winter ride/tow truck) 1994 Celica GT-4 Converted 1998 Celica GT-4 Converted 1987 Corolla FX 1986 Corolla AE86 (Next Project) |
I pieced the turbo set up together myself, and as far as horsepower 230-240. Just to give you a heads up this set up cut my mpg in half and I get about 18 mpg now.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
18MPG is not too bad, I was only getting 25 mpg on NA but I guess my ECU and some other stuff were never working right so I was always running rich. Show us some pictures of your engine bay jmeyer
so does anyone have a 1/4 mile time for the 4age swap?? or does anyone know what it could run?
There are gonna be a lot of variables with that, like tranny being used, mods, which style car you have and other stuff along those lines. To be perfectly honest I don't know any 1/4 times for the 4age but I wouldn't expect blinding fast speeds or anything.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) ![]() |
6 psi was the max I could get, but with aem methanol injection and cam gears I was able to get it up to 10psi without knocking. If you need any help let me know. Your setup has 8.5:1 gze pistons you said in your thread, he is not going to get close to that on stock silvertop internals. My large port is 9.4:1 my small port is 10.3:1 and the silver top is more than that, 10.5:1. This post has been edited by 97lestyousay: Apr 26, 2009 - 1:36 AM -------------------- JDM guy made me do it.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
Probably about 17-18 seconds for a 4age Celica lol.
3sge Celica is rated in the mid 15s -------------------- Mike W
Lo-Fi Version | Time is now: February 18th, 2025 - 10:20 AM |
