need help removing driver side axle |
Apr 22, 2009 - 5:25 PM |
Enthusiast Joined Feb 19, '08 From Elk Grove/South Sac Currently Offline Reputation: 0 (0%) |
i searched the site already and they said just to push it in and use your full body mass to pull it out when i tried that only half the axle came out from the inner rubber boot the part that connects to the tranny is still stuck in there is there a way to get it out without a axle puller?
Apr 22, 2009 - 5:54 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
lol. Its not gonna come out by just pulling on it like that, good try though.
Get a assortment of pry/crow bars, and on the part that goes into the transmission, there are deep ridges in the metal, made just for you to pry there! There is a snap ring that holds it in well so it takes some muscle. And be sure you have drained your transmission fluid or some will come through when you pull the axle. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Apr 22, 2009 - 6:14 PM |
lol. Its not gonna come out by just pulling on it like that, good try though. Get a assortment of pry/crow bars, and on the part that goes into the transmission, there are deep ridges in the metal, made just for you to pry there! There is a snap ring that holds it in well so it takes some muscle. And be sure you have drained your transmission fluid or some will come through when you pull the axle. thanks |
Apr 22, 2009 - 8:19 PM |
Enthusiast Joined Apr 22, '09 From Work Currently Offline Reputation: 2 (100%) |
Don't forget to get a new axle seal too. The driver side axle seal "will" probably get busted if your going the "prying it out" route. It takes time but it will come out.
-------------------- **If you can read this you are too close**
Apr 23, 2009 - 5:22 PM |
Don't forget to get a new axle seal too. The driver side axle seal "will" probably get busted if your going the "prying it out" route. It takes time but it will come out. tried praying it out still not coming out what other way is there or other tools o can use to get it out |
Apr 23, 2009 - 5:27 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
thats just about they way to do it, idk correct me if im wrong, but on most fwd cars thats how u do it. just try and keep the inner axle level, then find a spot that will give u good leverage, and go to town, dnt be affraid to use a big a** prybar, it makes life much easyer.
-------------------- Lift Addict!! ^_^
Apr 23, 2009 - 5:29 PM |
thats just about they way to do it, idk correct me if im wrong, but on most fwd cars thats how u do it. just try and keep the inner axle level, then find a spot that will give u good leverage, and go to town, dnt be affraid to use a big a** prybar, it makes life much easyer. haha yeah i been trying to do that all day haha but thanks to but is there a good spot to pry it out of the st tranny? |
Apr 23, 2009 - 5:37 PM |
just try to find an area that has good clearance to play with, sry i dnt have my car on hand to take a pic. if u have a 3-4 foot long prybar or one with an angled end, it should be np to pop out, put the tip of the bar against the backside of the axle, and then lean the bar against the tranny. push real hard a few times, and it'll pop out
Apr 23, 2009 - 5:42 PM |
just try to find an area that has good clearance to play with, sry i dnt have my car on hand to take a pic. if u have a 3-4 foot long prybar or one with an angled end, it should be np to pop out, put the tip of the bar against the backside of the axle, and then lean the bar against the tranny. push real hard a few times, and it'll pop out alright imma raise my car up a little higher so i can get a metal pipe on another pry bar and try it again but thanks man youve been very helpful |
Apr 23, 2009 - 7:45 PM |
np! hope it works for ya.
Apr 26, 2009 - 6:10 AM |
Enthusiast Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
I jammed a pry bar in the axle and had to hold it myself while I kicked it off. 5 hours of pain taking off that stupid driver side axle.
Apr 26, 2009 - 11:54 AM |
well atleast u got that sucker out of there!
Lo-Fi Version | Time is now: November 29th, 2024 - 12:13 PM |
