my car wont start, 3sgte swap..... |
Oct 15, 2003 - 11:47 AM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
OK. Have been working on the 3sgte swap into my 94 st. i have everything done. Last night arround 11:00pm , we tried to start the car.
everything is hooked up correctly ( i hope so ) but when i turn on the key all i hear is the fuel pump pumping and that's it. It doesn't try to crank at all. I have good power cause all the electrical is working fine. but i checked and we are not getting any kind of spark on the sparkplug wires. what could it be? i need help ppl. HELP ........ This post has been edited by sphinx_race911: Oct 15, 2003 - 11:48 AM |
Oct 15, 2003 - 1:09 PM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
check your coil... it might be bad
This post has been edited by NEVERSTOP: Oct 15, 2003 - 1:09 PM -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Oct 15, 2003 - 1:20 PM |
Enthusiast Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Yeah, hopefully you replaced all of the little things...such as coil, cap, rotor, etc. Check these things...and hopefully one of them will be the problem as they are less expensive than other parts. If this isn't your problem, have the starter tested?
Also, I had a problem when doing the JDM swap on my parents' 626 in which just one of the wires in the harness came loose that were related to ignition. Just make sure all connections are good and check those few parts. Hopefully your problem will be solved. -------------------- 95 Toyota Celica GT
Oct 15, 2003 - 2:12 PM |
Yeah, the coil is the only thing i can think is bad.
And yeah, i did replace the lil things, just not the coil. I'm gonna have to check it out when i get home today, and go buy one. |
Oct 15, 2003 - 3:40 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
did you ground the ignitor pack? my pack didn't have a good ground on it and it wouldn't fire.
Oct 15, 2003 - 5:39 PM |
Solenoid. Make sure u a) have it. 2) its properly connected.
The 6gc engines dont have separate ignitior packs, the 5th Gens do, make sure u have that. This post has been edited by Supersprynt: Oct 15, 2003 - 5:43 PM -------------------- |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:56 AM |
