94 celica, exterior door handles |
Apr 26, 2009 - 5:40 AM |
Enthusiast Joined Aug 13, '07 From Arizona Currently Offline Reputation: 1 (100%) |
Does anyone know how to remove the exterior door handles because i want to paint my car but w/o the door handles on it If someone could get some pix and directions I will truly appreciate it
Apr 26, 2009 - 8:01 AM |
Does anyone know how to remove the exterior door handles because i want to paint my car but w/o the door handles on it If someone could get some pix and directions I will truly appreciate it youll need to remove the door panel, (i believe there are instructions in one of the speaker how to's.) then pull back the plastic door liner, and reach into the door panel, and remove the 2 arms attached to the doorhandle. the one that moves the doorlock is pretty easy, you just flip the little plasic clip up, and pull the arm out. i like to do that one first, remove the 2 10mm bolts that hold the handle in the door, then pull the handle out and down to expose the arm that moves the doorhandle that way you can remove it from outside the car. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 26, 2009 - 8:08 AM |
Enthusiast Joined Apr 25, '09 From Ohio, USA Currently Offline Reputation: 0 (0%) |
How much is it gonna cost you to paint your car?
-------------------- I still own my celica, but i'm parting it out and junking it.. Or selling as a whole. Have a honda prelude now :(
Apr 26, 2009 - 10:10 AM |
Thanks Presure 2 Hoping itll be as easy as you make it sound
Well since Im doing vocational school labor and use of the facility is free over all Ive put about 600 towards my paint job just cause of materials and body parts. My paint is nason which is like 120 and clearcoat about 130 and i used primer which was 60 so about 210 if all you want to do is paint it not bad when you think about it =) |
Apr 26, 2009 - 11:18 PM |
Where can i find that link? For the speaker how 2? Im trying to picture how to do it and what ways to work with it any special tools ill need
Lo-Fi Version | Time is now: November 28th, 2024 - 2:37 AM |
