2 Pages V  < 1 2
> Electrical Problems (checked ALL fuses), Dome Lights, Hazards & Clock not working
post Jun 7, 2009 - 9:55 PM
smartsalman
Joined Apr 26, '09
From Hamilton, ON
ok.. tomorrow morning.. im gonna check like EVERY single possible ground.. that i could find..
post Oct 4, 2014 - 1:11 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
I'm having the same issue. i figured out how to the interior lights to function, however still no chime or clock...
post Oct 13, 2014 - 3:50 AM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (garin @ Oct 4, 2014 - 1:11 AM) *
Does your cigarette lighter ring light up and does your door indicator turn on in your gauge cluster? If yes to both, check your integration relay with a voltmeter, the brown box which is part of the fuse panel on your drivers side. Also just to check, do you have your keys in the ignition when opening your door? I know its a strange question but the door chime is mainly to let you know your keys are in the ignition.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Oct 14, 2014 - 1:22 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
how do i check the relay? what kinda voltage spec am i looking for?
post Oct 15, 2014 - 12:20 AM
igpx12
Joined Jan 30, '14
From Cortland NY
http://imagizer.imageshack.us/v2/xq90/540/aUiZYr.jpg
http://imagizer.imageshack.us/v2/xq90/908/GkBD7q.jpg
http://imagizer.imageshack.us/v2/xq90/538/tgvigU.jpg
http://imagizer.imageshack.us/v2/xq90/674/9IdLUh.jpg
Here's a layout of the wiring at the kick panel and integration relay. You basically wanna check the dome line for the clock and as far as the door, it should be linked in with the open door warning light. Test around though and see what you find.
post Oct 20, 2014 - 2:45 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Here's a fun one.
My dome light works, the door open warning light works, but the clock does not work... kindasad.gif
post Oct 21, 2014 - 12:16 AM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (KAOS @ Oct 20, 2014 - 3:45 PM) *
Here's a fun one.
Clock doesn't work period? That is a tough one. Going through sequence basically when the key is turned to acc that signals the clock to power on, the dome fuse provides power at that point to illuminate the clock and isn't controlled by the dimmer until your tail light relay enabled when you turn on the marker lights. Going through that rules out that yours could be a fuse issue, I would suggest getting a clock from another car or take yours out and try it in another. Simply put the backlight of the clock is probably bad, let me know what you come up with.
This post has been edited by igpx12: Oct 21, 2014 - 12:18 AM
post Oct 21, 2014 - 3:18 AM
the clock does not have a back light its a built in LED number display that dims. swap in a new clock, and report...
post Oct 21, 2014 - 3:06 PM
KAOS
Joined Apr 18, '06
QUOTE (njccmd2002 @ Oct 21, 2014 - 2:18 AM) *
Swapped out the clock with a known working one.
Same issue.
post Oct 21, 2014 - 6:18 PM
hmm, i would grab a multimeter, and test the illum and B+ see whats going on there...
post Oct 21, 2014 - 9:51 PM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (njccmd2002 @ Oct 21, 2014 - 7:18 PM) *
Definitely multimeter would be the best bet, test it by having the key in the off position and turn the key to acc with the mentioned lines.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 4:45 AM
