> Removing oil pump - 5sfe, How to drop oil pan
post Apr 26, 2009 - 11:21 AM
dgbldr
Joined Sep 19, '08
From Michigan
I've decided to replace the oil pump-to block gasket while I'm doing all the timing belt stuff. To do that I have to drop the oil pan. But at the moment the oil pan is sitting on a jack, supporting the engine. So:
1. Can I just re-install the pass side engine mount temporarily, will that give me enough room to get the oil pump out and in? Or do I need to hang the engine from a hoist?
2. Can I drop the oil pan enough without taking out the member? I think I can get to all the bolts.
3. Does Toyota sell an oil pan gasket? Shop manual shows using RTV, but that would be a bit tricky to do in place without taking down the member and oil pan. A real gasket I think I can fish in there.
Thanks guys.
post Apr 26, 2009 - 11:31 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
sorry bro, its FIPG only on the oil pan. and yes you have to drop the pan to get the pump off.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 29th, 2024 - 3:57 PM
