Time for a new muffler, Advice? |
Apr 26, 2009 - 5:09 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
I already have the ebay header installed along with a flex pipe and performance catalytic converter. I need a new muffler now and the piping that rides up and over the rear pass-side axle. I did have an Aeroturbine Muffler but I want something that will be more acomadating for my exhaust setup. Something that sounds deep and doesn't get tinny in the upper RPM range. Any ideas?
Apr 26, 2009 - 5:35 PM |
http://www.aeroexhaust.com/car_muffler_2525xl.html
This one seems interesting but has a built in resonator, will that reduce power for me? |
Apr 26, 2009 - 5:44 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
if u have your stock res, then u dnt need another one, the best way to get a deeper exhaust note is to replace your stock resonator with say a magnaflow one, that will almost kill all your tinny sounds, unless your muffler packing is gone. lol
This post has been edited by Ryouxrs: Apr 26, 2009 - 5:44 PM -------------------- Lift Addict!! ^_^
Apr 26, 2009 - 5:54 PM |
I don't have the stock resonator anymore.
so with a resonator, my exhaust will sound better than if I just had a performance muffler. So I need to get a muffler AND a resonator for optimal sound/gain? This post has been edited by 6G96GT: Apr 26, 2009 - 5:56 PM |
Apr 26, 2009 - 6:54 PM |
having a res. will give less performance than a sraight pipe, but it will not make a huge impact on performance either way if its a straight through design, and will sound MUCH better.
Apr 26, 2009 - 7:16 PM |
having a res. will give less performance than a sraight pipe, but it will not make a huge impact on performance either way if its a straight through design, and will sound MUCH better. you've never seen the inside of a resonator have you? the performance impact is about as great as...well nothing. it IS a straight through pipe. -------------------- |
Apr 26, 2009 - 7:25 PM |
having a res. will give less performance than a sraight pipe, but it will not make a huge impact on performance either way if its a straight through design, and will sound MUCH better. you've never seen the inside of a resonator have you? the performance impact is about as great as...well nothing. it IS a straight through pipe. i know this, thats why i said its almost nadda. but some stock res. have chambers, and retarded bends and such causing higher back pressures -------------------- Lift Addict!! ^_^
Apr 26, 2009 - 8:20 PM |
i've never seen a resonator with any of that, that would be a muffler. just because its not at the end if the system doesnt mean its not a muffler. and then some OE systems have a resonator at the end.
Apr 26, 2009 - 8:23 PM |
yes there are resonators like that, blame it on gm, and nissan, some of there vehicles do have resonators like that, not mufflers
Apr 26, 2009 - 9:33 PM |
so...would I want to get the Aero muffler with the resonator built in it? Or just get a regular performance muffler? I don't want to loose torque, I could care less about horsepower.
Apr 26, 2009 - 9:46 PM |
the bigger your pipe the less low end u will have, but the more topp end u will have, im not sure about that muffler, no idea how it works, but if u want deeper tone and a nice performance sound, get a performance, decent brand resonator, and a straight through muffler, but not a 30 dollor autozone special. lmao
Apr 26, 2009 - 9:58 PM |
Any brand names on those?
Apr 26, 2009 - 10:01 PM |
its more of what your happy with search around on the forums for exhaust clips and listen for a tone u like, id personally go for a vibrant or magnaflow resonator with an apexi n1 muffler or a magnaflow muffler
Apr 27, 2009 - 7:30 AM |
yes there are resonators like that, blame it on gm, and nissan, some of there vehicles do have resonators like that, not mufflers no, if it has a baffle it would be a muffler QUOTE Resonators, also known as Helmholtz resonators are sections of exhaust pipe that expand to a larger diameter and allow the sound waves to reflect off the walls and cancel out. Resonators are mostly used to reduce raspiness and popping. Resonators are similar to an Expansion chamber, only for 4 stroke engines. They do not produce much back pressure. Muffler! Resonator! -------------------- |
Apr 27, 2009 - 11:59 AM |
, ok im sry, but when the box, and part say res. and it has chambers im forced to believe the manufacturer, i know what the diff. between a muffler, and a res is, but thanks u for the refresher
Apr 30, 2009 - 4:06 AM |
Ah, someone else got here to explain that all these ads for resonators aren't for resonators.
The Aero linked does not describe a resonator, but a straight-through: "A built in Resonator before our patented Air Foil is packed with high temperature ceramic packing." Resonators aren't stuffed with packing/insulation; absorption mufflers are packed. Resonators are hollow; they ring when struck. A straight-through muffler is often mistaken for a resonator because it isn't baffled, and because a round muffler appears much like a resonator from the outside. Straight-through mufflers can be good designs; they are a modern take on the classic and now deeply outmoded glass pack. However, they address volume rather than tone. A smooth exhaust note almost requires a resonator in the system (some engines are smooth by themselves). |
Apr 30, 2009 - 5:32 AM |
Enthusiast Joined Jul 29, '07 From Quebec, Canada Currently Offline Reputation: 0 (0%) |
BORLA PRO XS, I have it, its free flow, cut the sound a lot and sound VERY DEEP
less than 90 bucks on ebay |
May 3, 2009 - 9:59 PM |
Enthusiast Joined Jan 27, '09 From New Orleans Currently Offline Reputation: 4 (100%) |
get a glasspack or cherrybomb muffler!!!
LOL i have a purple hornie glasspack muffler on my 1978 k5 blazer and it sounds like a freekin monster truck! (could be because it is also a straight pipe from the engine tho) lol gl with the choices you have btw this is a pic of it This post has been edited by NewOrleans: May 3, 2009 - 10:01 PM -------------------- |
May 3, 2009 - 10:32 PM |
Enthusiast Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) |
If you want something that doesn't get raspy at high RPMs, then you need to look into name brands (ie. Greddy) and just as Ryouxrs said, you'll need a resonator.
In fact, probably 90% of the tone is derived from the resonator. I just put a Greddy SP 2 muffler on my stock system (stock resonator) and it's a little bit louder (less baffling inside of the muffler, newer filling, etc.) but the tone itself is almost exactly matched to my stock exhaust. Thanks to this, I've got an increase in power, but without pissing off my neighbors when I come home at 4-5am. Your first step should be to look into getting a resonator, the second step should be your muffler itself. If you also want it to be a little bit deeper and meaner, enlarge your piping. I believe that standard piping on the GTs are 1.75" most people here say that you should go to 2.25" if you keep it N/A, or 2.5" if you turbo it. Your headers should be 2.25" already, or possibly 2.5". Take it to a muffler shop and have them remove and re-weld all of the piping. You'll love the outcome. -TC This post has been edited by razor7: May 3, 2009 - 10:34 PM -------------------- Live your life for yourself. Don't hold back for anything or anyone.
May 4, 2009 - 2:03 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
2 Magnaflow resonator Apexi N1 2.5 inlet 4in outlet and run 2 1/4 piping worth a try??
This post has been edited by 808celica: May 4, 2009 - 2:04 AM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:49 AM |
