Quick Questions, exhaust related... |
Apr 27, 2009 - 1:32 PM |
Enthusiast Joined Oct 22, '08 From Eden, NC Currently Offline Reputation: 0 (0%) |
First, I have no idea what kind of resonator to get... I guess there's no real difference in any of them but how they affect the sound, but I'm looking around and I see all these different types of resonators, just dont know which one to pick
Second, round or oval magnaflow high flow cat? Appreciate the patience in advance, I know I'm probably the 783sjhf928 millionth person to ask these questions |
Apr 27, 2009 - 1:42 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
First, I have no idea what kind of resonator to get... I guess there's no real difference in any of them but how they affect the sound, but I'm looking around and I see all these different types of resonators, just dont know which one to pick Second, round or oval magnaflow high flow cat? Appreciate the patience in advance, I know I'm probably the 783sjhf928 millionth person to ask these questions FIRST IF YOU LEAVE IT OFF ITS NOT A HUGE DIFFERENCE IN SOUND SECOND A magnaflow high flow cat IS NOT A resonator THIRD IF YOU DONT FIND THE ANSWER HERE JUST GO TO ANY EXHAUST SHOP AND THEY CAN EXPLAIN IT -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 27, 2009 - 2:09 PM |
Pertaining to the 2nd question I had... I know a magnaflow high flow cat isn't a resonator, I was just wondering if there were any differences between a ROUND magnaflow high flow cat or an OVAL one... I'm assuming no huge difference, but if there are any I'd like to know...
Round: http://cgi.ebay.com/ebaymotors/MagnaFlow-H...sQ5fAccessories Oval: http://cgi.ebay.com/ebaymotors/94106-Magna...sQ5fAccessories Again, thanks in advance |
Apr 27, 2009 - 9:32 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
the oval seems to be more of a primary cat than the round one, but as for a res. look into magnaflow or vibrant. and dnt leave this out, if u do a full exhaust it will sound like a honda fart can with out it
-------------------- Lift Addict!! ^_^
Apr 30, 2009 - 3:55 AM |
The shape of a catalytic converter is irrelevant, except that ovals fit under the car better -- more ground clearance. The question is matching the type of converter (e.g. TWC, TWC with air, etc) and its capacity (engine size).
However, I do have to point out that MagnaFlow offers a universal catalytic converter design with a resonated core; two-in-one function saves space in your exhaust design. Be aware that almost every piece of aftermarket exhaust equipment you see labelled as a resonator is not a resonator. All these underbody round mufflers are just that, mufflers. MagnaFlow's are a good design, Cherry Bombs are bad, but they are mufflers rather than resonators. The Celica, like almost every car manufactured, comes with a stock resonator. Get under your car and tap it; it will ring like a bell. A muffler, particularly the straight-through mufflers popular for underbody use, absorb sound via insulation. A resonator is an echo chamber, bouncing sound waves off each other to cancel out the noise. Mufflers deal with volume; resonators deal with tone. This post has been edited by Galcobar: Apr 30, 2009 - 3:58 AM |
Apr 30, 2009 - 12:38 PM |
The shape of a catalytic converter is irrelevant, except that ovals fit under the car better -- more ground clearance. The question is matching the type of converter (e.g. TWC, TWC with air, etc) and its capacity (engine size). However, I do have to point out that MagnaFlow offers a universal catalytic converter design with a resonated core; two-in-one function saves space in your exhaust design. Be aware that almost every piece of aftermarket exhaust equipment you see labelled as a resonator is not a resonator. All these underbody round mufflers are just that, mufflers. MagnaFlow's are a good design, Cherry Bombs are bad, but they are mufflers rather than resonators. The Celica, like almost every car manufactured, comes with a stock resonator. Get under your car and tap it; it will ring like a bell. A muffler, particularly the straight-through mufflers popular for underbody use, absorb sound via insulation. A resonator is an echo chamber, bouncing sound waves off each other to cancel out the noise. Mufflers deal with volume; resonators deal with tone. X2 on this, and your right about the cats, i was just going off what most primary and secondary cat systems look like. -------------------- Lift Addict!! ^_^
May 19, 2009 - 10:11 AM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
However, I do have to point out that MagnaFlow offers a universal catalytic converter design with a resonated core; two-in-one function saves space in your exhaust design. Would you be able to post up some links to this resonator/cat converter you've mentioned? -------------------- |
May 19, 2009 - 10:14 AM |
the oval seems to be more of a primary cat than the round one, but as for a res. look into magnaflow or vibrant. and dnt leave this out, if u do a full exhaust it will sound like a honda fart can with out it while this may be the case on a honduh, that is not the case with the celica, provided your not running a "fart can" muffler. a resonator will make the car more mellow, and quieter. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
May 20, 2009 - 4:10 AM |
However, I do have to point out that MagnaFlow offers a universal catalytic converter design with a resonated core; two-in-one function saves space in your exhaust design. Would you be able to post up some links to this resonator/cat converter you've mentioned? I found it via the Car Sound/MagnaFlow website; you're looking for ones in the 94400 range. The 2.25" one is the 94404. |
Lo-Fi Version | Time is now: January 10th, 2025 - 10:05 AM |
