Spark Plugs..., they ready to be changed? |
Oct 15, 2003 - 7:45 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
My dad bought this celica brand new in 1994... now it goes to me.. it has 83,000 miles on it, i was wondering should i change the spark plugs??? the car runs fine, it starts fine and seems to do everything fine... but do u guys think i should get a new set of sparkplugs?? if so what should i get... and will there be ne difference??
Oct 15, 2003 - 9:44 PM |
83K wow thats really low. When i bought my 94 it had 130,000.
Take them out and have a look. If its not broken, dont fix it. U can clean them and maybe re-gap them but if everything is fine, then just leave em. -------------------- |
Oct 16, 2003 - 12:11 AM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
when my car is running I check them in my 3sgte every 2 weeks to check for carbon deposits etc... spark plugs are the 1st indicator of bigger problems so check them often and replace them at least every 5-7k miles if not more often
-------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Oct 16, 2003 - 6:52 PM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
plugs dont have to be replaced for like 100k miles... Damn neverstop you change that sh!t often... that must be pricey if your running premium plugs!
anyways changing the spark plugs is what a shop would do if you went to get a tune up. Thats all they do, nothing else! maybe the wires but not usually... Some regular plugs for an ST should run you about $8, the tools, if you dont have any, should be like $5-$20 if you buy a socket wrench, extension arm, and spark plug socket (which is 5/8ths if you were wondering) |
Oct 16, 2003 - 8:46 PM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
I'd replace plugs every (about) 60K...
As for which to get, factory plugs (whatever is mentioned in your handbook) will do just fine. |
Oct 16, 2003 - 9:03 PM |
Depending on your car its either Denso or NGK.
Oct 16, 2003 - 11:22 PM |
Enthusiast Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) |
Whatever you do don't get cheap bosch plugs or anything like that. I put those in my car when I first got it, and after 5,000 miles they were all burnt up. I've been running Denso iridiums since then with no signs of wearing.
Oct 18, 2003 - 5:40 PM |
Denso's are stock, I had the original denso's in my car until about 120,000... I have NGK's now. I would personally never use bosch or split fire, but I dont see why they would suck any more then any other companies.
Lo-Fi Version | Time is now: January 9th, 2025 - 8:29 AM |
