Oct 20, 2003 - 10:02 PM
Enthusiast ![]() ![]() Joined Oct 13, '03 From Dandridge, Tennessee Currently Offline Reputation: 0 (0%) |
haha
-Brandon -------------------- ![]() |
Oct 22, 2003 - 3:55 AM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '03 Currently Offline Reputation: 0 (0%) |
Yeah mandrel bent piping has the same diameter around tight corners. Crushed bent usually wrecks air flow because the inside of the pipe doesn't stay smooth around bends.
Also Matt said from cat back but I think you should get a full exhaust, from the engine to the back - which includes a header, probably a new catalytic converter (removes toxins from exhaust) a new muffler, and the piping between them all. There are a couple of reasons for getting a custom header. Firstly if you get it in stainless steel it will look great. Secondly you will get a noticable performance gain from a well crafted header. Go for 2-2.5" pipe. If you go to a decent shop you will have the choice between stainless or mild steel. Stainless buffs up nicely while mild is unrelective and looks dull. Mild steel will hold up rust ok though. I'm getting a full exhaust in the next month or two, and I'm going to get a stainless header, a stainless cold air intake, and the rest of the system (piping and cat) will be mild steel except for the stainless muffler and tip. PS. If I was getting a body kit without mags, I'd get some lower springs to drop the right high because it will look weird without them. In fact if I were you I'd get some nice wheels and a suspension drop with the money for the kit. Celicas look nice on the outside without kits, especially with wheels and lowered. You could get a kit when you get some more cash, but that's just my opinion! |
Oct 23, 2003 - 9:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
I was gonna get a kit but instead got rims, and i havent lowered yet and i have gotten nothing but compliments. Definetly go wheels and drop first. If u get a kit then u have to save for paint. or just paint the kit and have it not be a perfect match
Oct 24, 2003 - 4:08 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '03 From Virginia Currently Offline Reputation: 0 (0%) |
It could be a perfect match if you use Toyota OEM Paint Codes. Just paint the kit piece by piece and then when it is all painted, slap it on the car.
But I, in no way would go that direction. If I were to get a kit, I would get the entire car painted again. This post has been edited by Inferno: Oct 24, 2003 - 4:09 PM |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 3:11 AM |
