5 Pages V  « < 2 3 4 5 >
> 808's car problem thread lolz, done goose hunting for solutions
post Jan 3, 2010 - 11:18 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Bitter @ Jan 3, 2010 - 5:49 PM) *
use a ziptie to hold it into place, see if the problem still exists.
laugh.gif one step ahead of you. Now I can truely say this car is completely ghetto rigged
This post has been edited by 808celica: Jan 3, 2010 - 11:18 PM
post Jan 4, 2010 - 12:35 AM
Ted95
Joined Mar 8, '09
From Westport, MA
this **** is happening to my car now at the moment.. it **** the bed and took soooo many cranks to get it runnin and when i got it running, it ideled lowww and when it was back to normal and gave it gas it gagged... we thinkk its the map sensor but we aint positive.. my codes came up as 24 and 31, one being a temp sensor and the other the map senor... cars in the shop now being looked at
st205 powered ss3 coupe
post Jan 4, 2010 - 2:17 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
wow that sucks man. Im not getting those codes (knock on wood) everything seems alright ATM, so i'll go drive out for gas.
***01/03/2010 10:12pm I think i found the problem. Fool around with every wire and part associated with the trouble code. Use a zip tie and a rubberband. Test drive, bridge TE1 and E1 terminals in diagnosis box and you get a continuous flashing CEL with key turned to ON. Continuous flashes means trouble gone!!! WTF!!!!!!
This post has been edited by 808celica: Jan 4, 2010 - 3:14 AM
post Jan 4, 2010 - 8:11 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
then it may have just been a bad connection.
post Jan 6, 2010 - 3:15 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
K that didnt solve the problem i just got lucky. with my new experiences now i have a better idea when the problem comes about.
Engine starts no problem when cold, but once the engine is warmed up that's when the idle drops and the car dies. After this I wasnt able to start the car again even with me fooling around with connections.
Now in my garage i warmed the car up then came back and gave the engine gas-------car doesnt stall
Gave it more revs are diff rpms to make sure that wasnt a fluke. This seems good.
Now coincidentally my dad touchs the oil pressure sensor and the car dies (no throttle given)
So i take out the sensor connector and shoot electronic cleaner (like brake cleaner but wont harm plastic)----Car starts (problem solved or a fluke?)
Well.......that was a fluke, car is running regular idle then a little gas was given and car dies. wtf?!?!?!
Car started right away again. My dad and I kept re-creating what we did to make the car die. No go car runs and didnt die out. So i turn off the car and call it a night.
Thoughts??? Next thing I should check is the igniter near the brake master cylinder on the firewall. Might have to drive out with Herosblade's igniter and drive in circles around the neighborhood until the car dies. Then carefully remove my igniter and install his. If the car starts and dont die Igniter is my problem (wont know till i try) If I still stall and die I'm lost frown.gif
So would a faulty oil pressure sensor cause the car to shut off?? Also those 3 sensors at the end of the radiator hose, would they cause the car to shut off?? Other than that those were the only things my dad and I touched that caused the car to shut off at warmed temp.
post Jan 6, 2010 - 2:46 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
k this morning the started the car and took a shower. came back down and the car was still running by itself at warm temp. i gave aboout 10-15 short 2500 revs and the last rev it died. i tried to start it back up but it wouldnt. so i waited 5 mins and tried again, 4th try it kinda started but i had to give gas (1500rpm worth) for the engine to stay alive for 5 secs. after that it wouldnt start.
post Jan 9, 2010 - 1:41 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
changed igniter module, problem still exists frown.gif its not throttle position sensor, idle air valve thing, or vac hoses. Its something electrical but i can find it. Still gettin hte code 12 checked distrib and connection, igniter and connection. what's left to check?? Last thing i know is ECU. help much??
This post has been edited by 808celica: Jan 9, 2010 - 1:42 AM
post Jan 9, 2010 - 3:25 PM
Bitter
Joined Mar 11, '06
ya'll got mice and rats on them islands, check all the wiring.
post Jan 9, 2010 - 4:23 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
wiring checked. now throwing code 14. checked connecter E5 pins 20 and 3 for IGT and IGF. those checked out. I'm not bothering with an ecu swap from Herosblade's car so either I find a good priced ecu (will be specific to my car) or the car will be parted and chopped. So you can start calling dibs on replacement parts cuz Herosblade got first dibs on lips.
This post has been edited by 808celica: Jan 9, 2010 - 4:24 PM
post Jan 9, 2010 - 5:25 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (808celica @ Jan 9, 2010 - 4:23 PM) *
i want your clear door lights!!
post Jan 9, 2010 - 6:00 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
post Jan 9, 2010 - 9:07 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (benzo @ Jan 9, 2010 - 12:25 PM) *
just use a tundra clear lens. search for my interior thread or search clear door lens and grab the p/n its way faster for oyu that way
QUOTE (OOBE @ Jan 9, 2010 - 1:00 PM) *
anywho pin 20 and 3 on E5 connector was tested for ignition signal to the ecu. the IGT terminal isnt givng me 0.5-1v when igniter connector is removed and you "crank" the engine for no more than 2secs a time. also it must not read 0 or 5v on the IGT terminal. Problem isnt solved but I think I found my problem, the last option, ECU.
post Jan 9, 2010 - 9:14 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
You getting an IS350? I hate those cars. They're quick, but too uncomfortable inside for a sporty luxury car. The back has no room. Might as well be a Celica, lol.
post Jan 10, 2010 - 4:06 PM
DRAGN808
Joined Aug 12, '09
From Oahu
How much you want for the intake?
post Jan 15, 2010 - 10:44 PM
mak5603
Joined Oct 20, '08
how much for the gt4 strut bar?
2014 Toyota Rav4 XLE
post Jan 16, 2010 - 12:13 AM
richee3
Joined Jun 29, '08
From Denver
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 16, 2010 - 1:32 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (808celica @ Jan 9, 2010 - 11:23 AM) *
QUOTE (mak5603 @ Jan 15, 2010 - 5:44 PM) *
QUOTE (richee3 @ Jan 15, 2010 - 7:13 PM) *
Yes, I've bought a new ecu and still the problem exists.
post Jan 16, 2010 - 3:08 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Nooo don't part out and leave us!!! I will come down there and help you figure it all out frown.gif.
post Jan 16, 2010 - 5:47 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
laugh.gif did everything by the book. if it comes down to me pulling the motor just to get to something small im not game.
post Jan 16, 2010 - 8:26 AM
Bitter
Joined Mar 11, '06
i'm telling you, its in the wiring. de pin the wires associated with the code from the ecu harness, pin in new wires (dealer sells pre-pinned leads i think) and run new wires all the way to the offending sensor/part.
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 28th, 2024 - 5:50 AM
