2 Pages V  < 1 2
> Megan Radiator
post Sep 20, 2009 - 3:18 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how much does koyo or megan radiators weigh??
post Sep 21, 2009 - 8:50 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Domyz right about the stock radiator.
The OEM radiator in the GT4 is more than adequate to handle the 18 PSI I'm running. The radiator part number is the same in ST205 and ST202.
However while the cooling is fine, the plastic top tank gets brittle and cracks overtime as mine has, which is a good enough reason to go with a full aluminum race radiator.
Mike W
269awhp / 273ft-lbs
post Sep 21, 2009 - 10:19 AM
BonzaiCelica
Joined Apr 24, '08
hey delusionz, I already understood that aluminum radiator is not necessary on n/a car unless your using it strictly for racing.
Im looking for an aluminum radiator to save weight in the front of my car.
post Sep 21, 2009 - 11:22 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (BonzaiCelica @ Sep 21, 2009 - 11:19 AM) *
if saving weight is your concern, you should look for a smaller radiator rather than a bigger one.
your idea of a allunimum radiator being lighter is somewhat right, but remember bigger means more coolant, what's the weight of that again ?
I'd say go to autozone and buy a OEM replacement alluminum radiator, that will hold around the same amount of coolant as the stock one, but made in alluminum.
a Koyo or megan are bigger, thus weighting more after you take the coolant into account.
post Sep 21, 2009 - 11:37 AM
BonzaiCelica
Joined Apr 24, '08
hmm ya your right culpable, it is bigger. i was looking at integra type r vid and saw that it has a small aluminum radiator. Ill have to look into that at autozone or napa auto parts. thanks for that reply
post Feb 15, 2010 - 6:46 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (domyz @ May 14, 2009 - 5:42 PM) *
OEM rad is WAY sufficient for a non built up 3SGTE at 400hp or less, the only thing important is thermostat (TRD 160degree does great), nature of the coolant.
Radiators are always three or four times bigger than they need, a good exemple is an old civic SI (like 97) , their rad size is half of ours and is as good as the other cars, and it is also letting more cold air entering into the engine bay.
I would not pay 300buck for a rad that wont do anything more than stock one, I would search a smaller one with the same efficiency.
2cents
well I did happen to find a radiator that is half the size of our normal radiators. I actually remember seeing a radiator on a ek9 civic type r at super autobacs a while back and it only had one fan as well.
http://cgi.ebay.com/ebaymotors/ALUMINUM-RA...sQ5fAccessories
now the problem would be mounting the radiator and finding a fan for it. any ideas anybody? Finally found a lightweight radiator
link for radiator at autozone weighs 10.5 pounds and seems to be made of all aluminum, whats the weight of the stock radiator
http://www.autozone.com/autozone/catalog/p...equestid=377427
This post has been edited by BonzaiCelica: Feb 15, 2010 - 7:06 PM
post Feb 21, 2010 - 5:06 PM
BonzaiCelica
Joined Apr 24, '08
comments anyone ^
post Feb 27, 2010 - 11:05 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
its sweet.. half the size so you can go twice as fast.
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Feb 28, 2010 - 3:45 AM
BonzaiCelica
Joined Apr 24, '08
wow what a stupid comment, seriously i want real feedback
This post has been edited by BonzaiCelica: Feb 28, 2010 - 3:45 AM
post Feb 28, 2010 - 8:32 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i have one... its a manual radiator... etak found it somewhere... fits perfect and is more than half as thick... it has no transmission cooler (used only for autos)
Breaking Axles...
post Feb 28, 2010 - 9:41 PM
BonzaiCelica
Joined Apr 24, '08
cool thanks. Pictures??
post Mar 3, 2010 - 10:44 AM
1/2 size radiator wouldn't be a problem at all with a fan and run some water wetter type stuff.
SPAL thin fan = win if you're looking to really squeeze in some room savings.
post Sep 25, 2010 - 7:20 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (playr158 @ Mar 3, 2010 - 11:44 AM) *
What size fan would I get from http://www.spalusa.com/store/main.aspx?p=C...Body&c=FAHI
yo pittfirefighter were you saying that you had an ebay all aluminum radiator, the one thats half the size of our and 40mm thick.
So with a smaller radiator that increases the airflow from the front of the vehicle into the engine bay right??
This post has been edited by BonzaiCelica: Sep 25, 2010 - 7:49 PM
post Sep 25, 2010 - 7:48 PM
QUOTE (BonzaiCelica @ Sep 25, 2010 - 8:20 PM) *
what do you mean by this???
Honda people frequently swap over to 1/2 radiators
that combined with a SPAL thin fan, SPAL is a company that makes electric radiator fans. Thin models save both weight and valuable engine bay space while still being efficient in cooling.
Water Wetter is an additive to your cooling system (I personal run distilled water + water wetter, thats it)
"Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20° "
I ran distilled water + water wetter (summer only since you don't use any coolant) and i saw 15 degrees lower temps across the board.
post Sep 25, 2010 - 8:51 PM
BonzaiCelica
Joined Apr 24, '08
interesting stuff ok thanks for the reply. I just have to figure out which size fan I will get
The job of the fan in front of the radiator is to get air circulating in the engine bay right.
This post has been edited by BonzaiCelica: Sep 25, 2010 - 8:58 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 11:27 AM
