Enthusiast Joined Dec 28, '08 From Dublin, Ireland Currently Offline Reputation: 0 (0%) ![]() |
Hi,
I've a 1996 Jap Import ST202 6th gen Celica. The airbag warning light is on and I followed the instructions here to get a diagnostic fault code 14 which points to an ignition/ignition signal related problem. Which sounds about right, as the ECU clears the warning lights when I start her up, and only comes back on when I reverse a few meters out the driveway. But I just want to check whether fault code 14 means ignition problems when the engine management light is on, but might mean something else when the airbag light comes on. Are there separate interpretations of it ? I suspect there may be a separate minor dashboard wiring problem if the engine management light should've come on. I say this because when I indicate left or right, both left & right dashboard indicator lights flash simultaneously. Only once did this work, ie. only flashed left when indicating left, when I happened to have the heater on full. If the engine management light should've come on, then maybe someone was trying to hide the airbag light not lighting up, or I see someone had installed an old LED strip and may have messed up the wiring there... cheers, Owen |
code 14 (for US) =
open circuit between steering wheel pad and center air bag sensor; faulty steering wheel pad; faulty spiral cable; faulty center air bag sensor. basically, either you have a bad airbag, bad airbag ECU, or a bad spiral cable. most likely the spiral cable (or called a clock spring in the US) is bad. Easy to change if you can get a used one but you would still need to reset the airbag ECU code. -------------------- |
Thanks Batman722,
top man with the information & much appreciated ! ![]() I've an NCT test ( Irish car safety check ) coming up soon and am preparing the car. regards, Owen |
Lo-Fi Version | Time is now: February 20th, 2025 - 3:17 PM |
