Closed TopicStart new topic
> Are gt shifter cables the same as the st205 shiffter cables?
post May 12, 2009 - 10:46 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
Hey Am trying to get my lsd tranny to work but I keep having problems with the shiffter cables, I bouth some shiffter cables from the UK which the guy said their from a GT4 st205. I looked at them and they look pretty identical in length to the regular gt cables. Are they the same? My mechanincs says the gt are not long enough and the st205 dont seem much bigger.....
and about the rear mount, is their an alternative to it, cause i cant find that one.
post May 12, 2009 - 11:48 AM
QUOTE (02bluerolla @ May 12, 2009 - 10:46 AM) *
no they are not the same. and yes, you need a 205 mount and bracket.
post May 12, 2009 - 5:12 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
The GT gearbox has the cable mount as part of the box casting and the cable fixing is thicker for fitting into the casting. On the ST205 box, the cable fixing is narrower as the fixing is on the bracket that is bolted on to the gearbox.
Both cables are very much the same in length.
post May 12, 2009 - 6:17 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (jeffrosie @ May 12, 2009 - 5:12 PM) *
am i supposed to do something to the cables they dont reach?
Lo-Fi Version Time is now: November 27th, 2024 - 8:29 PM
