Enthusiast ![]() ![]() Joined Feb 2, '09 From new orleans La. Currently Offline Reputation: 5 (86%) ![]() |
Anyone know what engine code is 25? @ blinks pause then 5 blinks ?
I found the code means lean so what made my car run lean I just changed the plugs?
Here is a full list of codes and what they mean.
http://celicatech.com/forums/showthread.php?t=10155 25 - O2 Excessive Lean Air Fuel Ratio Check o2 sensor you have a problem with your o2 sensor, or your fuel pump. check both. this is also the cause of your other hesitation problem. This post has been edited by lagos: May 12, 2009 - 8:39 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
So fuel pump is the problem I think because of the code and the loudness of it and the sound of the pump changing alot from low to loud. Also I did have the wire on my o2 sensor was cut so I must have drove with it like that for a while but I have sinced spliced the wire back to gether
Took my fuel filter off today and it was filthy dirty. I am going to drop the tank and change the fuel pump. I dont think scc that did the swap installed my walbro fuel pump cause as I am taking everything off its seems like it has not been touched since the factory . What size wrench loosens the fuel lineunder the back seat? I tried a 9/16 and 13,14,15mm and there either to big or to small what size is it?
i |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
you need a special fuel line wrench...i forget what size it is but theres a special wrench for it
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
iirc its a 17, and a 14mm you'll need for the fuel line.
use a 14mm flare wrench, the fittings are soft and will strip if your not careful. -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
you dont need to drop the tank to get to the fuel pump
you dont need to drop the tank to get to the fuel pump I know I dont need to drop the tank. I pulled the pump a few minutes ago and the tank is full of trash like I thought. Thats why I am going to drop the tank so I can clean it out. The sock on the pump was clogged with rust colored gas and particles. The sock must be so clogged the pump is not sending enough gas when I am at wot thats why I the hesitation and the car breaking up. I am installing a new sock and filter tommorow after I drop the tank and clean it out. You can see all kinds of stuff on the bottom of my tank and floating around in the tank. Do you think not getting enough fuel at high boost was making me run lean and breaking up? |
maybe. go fix the problem and see how it goes from there.
Cleaned the tank out this evening and got the pump back on with a new strainer. Gotta pick up the fuel filter in the morning. should be finished tommorow. Hopefully this is the problem. I bcleaned the tank and there was alot of rust floating in the gas I drained and on the rag I wiped it out with. I am waiting to fix this then I am installing my ct27. I have a exhaust manifold from xs power. I did not install it on the original swap because I was told there crap/ Does anyone think its worth putting on the chrome xs manifold header? nOr tick with the oem manifold? Will the xs power mani give me more power than the oem mani?
its crap. throw it in the trash. all it will do is heatsoak your engine bay and then start to crack on you.
Gotta wait till monday the fuel filter was half way installed and it was the last thing to do before I start and test the car and the copper washers was left out the part box when I got it. so I have to wait till monday for them to get another pump and give me the washers. Tried to use the old ones but the would not seal and gas sprayed out. So I have to wait a little longer that sucks!
Its fixed it was the fuel stainer and fuel filter yippie!! I am on the road again and I have more power that I thought had lost before. Well I am happy
Lo-Fi Version | Time is now: February 20th, 2025 - 6:38 AM |
