code 12 and my car is going crazy |
May 13, 2009 - 12:58 AM |
Enthusiast Joined May 3, '09 From jacksonville/flemming island florida Currently Offline Reputation: 1 (100%) |
this started monday night after comming home. and car threw a check engine light which is a code 12 . code 12 is a tach rpm signal, or ecu fault
ok on the way to work car ran great after resetting the ecu, better than it had before but still had code 12. after i got to work, i unhooked the battery cable left if off till i got off 8 hours later. on the way home my car starts randomly missing, the lights both inside and outside are randomly getting bright and dim,and the speedo is going crazy, its jumping 5-10mph up and down from where it should be. any ideas? this is on a 94 7afe -------------------- 94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine 85 celica gt-s project |
May 14, 2009 - 9:13 PM |
well turns out the battery was shot, it had swollen , and the dizzy had gone bad as well, replced both, car runs good now
Lo-Fi Version | Time is now: December 4th, 2024 - 7:35 PM |
