> Random Crack From Hell! When driving!, Lets Diagnos this further.
post May 13, 2009 - 4:14 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Been occuring for almost a month now, Gentle or aggresive driving (accel/brake) + right turns seem to cause a "crack" or knock sound -> (eg. turn right as you exit the turn *crack* u counter steer *crack*)
Engine mounts r still shining pretty, engine does not have accesive movement, tie rods ends make no noise when cranking the wheel while stationary.
More suggestions Please, as well as how to test your theory!
post May 13, 2009 - 4:25 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
axel?
post May 13, 2009 - 4:53 PM
Mstoochn
Joined Apr 27, '09
QUOTE (LewFX @ May 13, 2009 - 4:25 PM) *
axel?
test this theory how?
post May 13, 2009 - 5:05 PM
LewFX
Joined Jan 28, '05
pop your hood open ,find your axle and see if the boots are torn or if theres any grease anywhere
post May 13, 2009 - 5:13 PM
Mstoochn
Joined Apr 27, '09
QUOTE (LewFX @ May 13, 2009 - 6:05 PM) *
Cv boots are good, only sight of any substance where its not supose to be is oilfrom the oilpan (small leak) FIGP ftl..
post May 20, 2009 - 8:39 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
its an axel. its probally the passenger side, carrier bearing.
I just replaced my axel and the bearing cuz they both went. (or 1 led to the other.)
Kawi Love
post May 22, 2009 - 5:38 PM
Mstoochn
Joined Apr 27, '09
QUOTE (devilsden97 @ May 20, 2009 - 8:39 PM) *
Will look into it. But its not immediate?
post May 22, 2009 - 5:41 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
its the axle. you want a vid of mines doing the same thing?
at a stand still i turn the wheel left to right and vice versa. all you hear is *click click click CLACK snap crackle pop*
post May 22, 2009 - 6:08 PM
Mstoochn
Joined Apr 27, '09
QUOTE (808celica @ May 22, 2009 - 5:41 PM) *
Hmm.. there is no noise at a stand only when at speed or turning at speed
post May 22, 2009 - 7:05 PM
95st-celica
Joined Mar 29, '07
From Philly
check wheel bearings as well but sounds like an axle.
to check your wheel bearings/hub's, jack the car up and take the tire at the top and bottom and push/pull on it...it should not move or make any weird noises, if it moves even a little bit you need new wheel bearings...do it side to side and top to bottom or in/out
1988 Dodge Aries K (sold)
post May 22, 2009 - 7:43 PM
QUOTE (808celica @ May 22, 2009 - 6:41 PM) *
that sounds like rice krispies, now im hungry
maybe the tie bars or the bearings..
post May 23, 2009 - 1:10 PM
Mstoochn
Joined Apr 27, '09
QUOTE (95st-celica @ May 22, 2009 - 7:05 PM) *
I don't even have to lift my car off the ground to tell u they move side to side with the steering locked (about half an inch) i just use my HE-MAN super strength and rip them back n forth. wheel bearings or carrier bearings?
post May 24, 2009 - 12:17 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
or tie rods... up and down is the test for wheel bearings.... left and right is inconclusive with the wheel on
Breaking Axles...
post May 25, 2009 - 8:35 PM
Mstoochn
Joined Apr 27, '09
QUOTE (pittfirefighter @ May 24, 2009 - 1:17 AM) *
I've cranked the wheel not in motion and u dont here it then. doesn't that rule out tie's
post May 25, 2009 - 8:39 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
the load it has to put up with. take that into consideration
post May 25, 2009 - 9:00 PM
Mstoochn
Joined Apr 27, '09
QUOTE (808celica @ May 25, 2009 - 8:39 PM) *
You trying to tell me im FAT.....
post May 26, 2009 - 12:02 AM
azian_advanced
Joined Apr 18, '05
From Calgary
lol
post May 26, 2009 - 3:07 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Mstoochn @ May 25, 2009 - 4:00 PM) *
goddamnit everything i post has to insult you in some way.
fine im done with helping noobs like you
post May 26, 2009 - 3:33 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (Mstoochn @ May 25, 2009 - 8:35 PM) *
i was referring to the left and right movement... just because the wheel moves left and right does not mean the wheel bearing is bad... up and down is the test for wheel bearing... your tie rods could be bad and not making any noise - a separate issue altogether
Breaking Axles...
post May 26, 2009 - 2:18 PM
Mstoochn
Joined Apr 27, '09
QUOTE (808celica @ May 26, 2009 - 3:07 AM) *
frown.gif ouch
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 27th, 2024 - 5:46 PM
