> 3SGTE question
post May 16, 2009 - 6:28 AM
CeLiCa_ST
Joined Jan 14, '08
From UAE
i swaped my celica engine 3SGE to 3SGTE & useing 3SGE tranny out of the beams engine...my problem is when I power shift it at high RPM (more than 7000rpm) it wont go in gear.
someone told that this problem may be caused by a bad lever cable, releasing bearing or from the fork.
so can somone help to figure this problem out PLZ....
thanx in advance....
post May 16, 2009 - 11:30 AM
try an extended slave pushrod from speed source.
post May 16, 2009 - 12:33 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
thank you lagos!! you may have just solved my problem as well!
Breaking Axles...
Lo-Fi Version Time is now: February 17th, 2025 - 11:35 AM
