engine removal |
engine removal |
May 22, 2009 - 6:29 AM |
Enthusiast Joined Mar 14, '09 From Portishead Currently Offline Reputation: 0 (0%) |
If I were to replace my engine, would I have to drop it from the bottom, or can I lift it out from the top? this matters as I dont have a lift or anything and limited garage space, so I have to lift out my engine if I am to replace it...
May 22, 2009 - 6:49 AM |
If I were to replace my engine, would I have to drop it from the bottom, or can I lift it out from the top? this matters as I dont have a lift or anything and limited garage space, so I have to lift out my engine if I am to replace it... the easiest way is with a engine lift, with the tranny connected. you hook a chain to the lift, put use 4 links from the lift to the passanger engine hook, and ~15 to the drivers. stick a jack under the tranny, and once all the mounts are out, you lower the tranny down, then lift the motor and tranny out together on a steep angle. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: December 2nd, 2024 - 2:17 PM |
