May 28, 2009 - 7:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Im not sure if this is in the right section but I thought I would put it in here.
I was driving my 1995 gts today, and i noticed that in 3rd 4th and 5th, that if i put it right to the floor, my rpm rises really quickly from 2000 to about 3500 rpm, but the speed is not going as fast as the rpm. the rpm will hit 3500 and then drop back down to 3000 and stay at 3000 while the speed increses. It does this in 3rd 4th and 5th, but not 1st or 2nd. I cleaned my engine today with degreaser and then rinsed it off with a hose but only trickled it lightly and was careful at what i got wet. Now Im not sure if a sensor just got wet or if this is something really serious. This was the first time driving my car after i cleaned the engine so it could have just been a wet sensor. It was been about 3 or 4 hours since i washed it and i currently have my battery disconected to reset everything in the car, and I am waiting a few minutes before I take it for a ride. If you know anything about what this could be, or what i could do to fix it that would be really helpful and I would appreciate any help. Thanks, Colin. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 28, 2009 - 9:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
sounds to me like your clutch is slipping. time for a new one.
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
May 29, 2009 - 12:16 PM
sounds to me like your clutch is slipping. time for a new one. Thats what i was thinking too, but wouldn't it be doing that in all the gears? not just 3rd 4th and 5th? And wouldn't that give me problems taking off from a dead stop, I've no porblems with that. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
May 29, 2009 - 1:06 PM
Enthusiast ![]() ![]() Joined Jul 29, '07 From Quebec, Canada Currently Offline Reputation: 0 (0%) |
wait sometime, maybe your clutch caught some oil/grease on it and will stop to slip in a time, mine did exactly that.... Don't make it slip for one or two weeks.
and cleaning of the engine bay must be a dry cleaning |
May 31, 2009 - 11:55 PM
Bump.. anyone else?
Jun 2, 2009 - 5:23 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Bump.. anyone else? Sounds like your clutch is going out, just a coincidence with cleaning your motor. You should be able to use a pressure washer on your engine and not get water anywhere near your actual clutch lining and such. It might do it in 1st and 2nd but is just less noticeable. It's typically more noticeable in higher gears because, for example, if you floor the car in 1st, the gear ratio is short enough that you just speed up quickly, but if you floor it in 5th the gear is so long it takes a lot of effort to increase speed/RPM. That effort, with a worn clutch, just becomes the motor revving faster. All you can do is replace it. If there is actually water and such getting into there, you should still replace it and replace whatever is allowing foreign contaminants in. -------------------- 1999 Celica GT
Jun 2, 2009 - 7:36 PM
Bump.. anyone else? Sounds like your clutch is going out, just a coincidence with cleaning your motor. You should be able to use a pressure washer on your engine and not get water anywhere near your actual clutch lining and such. It might do it in 1st and 2nd but is just less noticeable. It's typically more noticeable in higher gears because, for example, if you floor the car in 1st, the gear ratio is short enough that you just speed up quickly, but if you floor it in 5th the gear is so long it takes a lot of effort to increase speed/RPM. That effort, with a worn clutch, just becomes the motor revving faster. All you can do is replace it. If there is actually water and such getting into there, you should still replace it and replace whatever is allowing foreign contaminants in. Alright thanks a lot, I mean, yea I don't want to replace my clutch lol but I'd rather know. So there is nothing else it could really be? Is it an issue if I let it get worse first cause i really can't afford to fix it right now, like is it going to do any damage on anything else or should i get it fixed right away? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 2, 2009 - 10:20 PM
Bump.. anyone else? Sounds like your clutch is going out, just a coincidence with cleaning your motor. You should be able to use a pressure washer on your engine and not get water anywhere near your actual clutch lining and such. It might do it in 1st and 2nd but is just less noticeable. It's typically more noticeable in higher gears because, for example, if you floor the car in 1st, the gear ratio is short enough that you just speed up quickly, but if you floor it in 5th the gear is so long it takes a lot of effort to increase speed/RPM. That effort, with a worn clutch, just becomes the motor revving faster. All you can do is replace it. If there is actually water and such getting into there, you should still replace it and replace whatever is allowing foreign contaminants in. Alright thanks a lot, I mean, yea I don't want to replace my clutch lol but I'd rather know. So there is nothing else it could really be? Is it an issue if I let it get worse first cause i really can't afford to fix it right now, like is it going to do any damage on anything else or should i get it fixed right away? You won't really hurt anything, it will just be inconvenient. You can drive it a while if you baby it and keep it from wearing much more, but eventually you'll get to the point where it's unsafe to drive. -------------------- 1999 Celica GT
Jun 3, 2009 - 9:45 AM
Bump.. anyone else? Sounds like your clutch is going out, just a coincidence with cleaning your motor. You should be able to use a pressure washer on your engine and not get water anywhere near your actual clutch lining and such. It might do it in 1st and 2nd but is just less noticeable. It's typically more noticeable in higher gears because, for example, if you floor the car in 1st, the gear ratio is short enough that you just speed up quickly, but if you floor it in 5th the gear is so long it takes a lot of effort to increase speed/RPM. That effort, with a worn clutch, just becomes the motor revving faster. All you can do is replace it. If there is actually water and such getting into there, you should still replace it and replace whatever is allowing foreign contaminants in. Alright thanks a lot, I mean, yea I don't want to replace my clutch lol but I'd rather know. So there is nothing else it could really be? Is it an issue if I let it get worse first cause i really can't afford to fix it right now, like is it going to do any damage on anything else or should i get it fixed right away? You won't really hurt anything, it will just be inconvenient. You can drive it a while if you baby it and keep it from wearing much more, but eventually you'll get to the point where it's unsafe to drive. Alright thanks a lot. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 11:45 AM |
