> front brakes & rotor -st204 conversion to st205
post May 29, 2009 - 5:28 PM
97gt5sfe
Joined May 11, '09
From Las Vegas
I recently purchased front calipers but need the parts to hold the pads in -not sure what its called. Not sure how to get them. Also looking for aluminum hat light weight slotted rotors to go with them. Has anyone done this conversion, and if so what's the easy way? Will the caliper just bolt on without any mods?
post May 29, 2009 - 11:21 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (97gt5sfe @ May 29, 2009 - 5:28 PM) *
for aluminum hat ( basically a 2 peice custom rotor ) get ready to pay over 500 for one set, I can get you front rotors ( slotted, drilled, plain, or slotted + drilled ) that will fit with the set-up as well as the instructions needed to complete the job ( very simple modification if you know how to use a wrench )
if you're interested, let me know,
This is a custom rotor, design to work with ST205 calipers and McPherson suspension.
if you have a picture of the part you are missing, I can get you a part number for you to order it from the dealer.
post Jun 1, 2009 - 4:38 PM
97gt5sfe
Joined May 11, '09
From Las Vegas
QUOTE (Culpable04 @ May 30, 2009 - 12:21 AM) *
This caliper has a different style clip to hold the pads in. I was looking into Wilwood rotors or something that looked like it, slotted and drilled with a black hat. Is the offset the same as the GT with just a larger diameter, or custom offset with the GT hubs? Sounds like you've done this before, thanks for your help.
post Jun 1, 2009 - 9:05 PM
Culpable04
Joined Apr 17, '06
From New Jersey
wilwood would probably make you a custom rotor, but you have to give them the specs, so you have to calculate the offset where the calipers will fall, so the rotor is dead center on the caliper, also you need to give them the thickness of the disc, the diameter where it'll cover the pad and stuff. and after you get all this info, it'll cost you a pretty pennie.
I'll post my set-up this week, if you are interested, my rotors are not a 2 piece rotor, I have the traditional style one piece, but it'll save you from doing all this calculation, which I can say, is a pain. you'll also need spacers to clear the calipers depending on the wheels you have.
I can get you rotors + spacers that have great quality for our demands and are still affordable for everyone.
the metal piece that you describe can be ordered from the dealer, the part number is 47748-14080 Spring, anti-rattle No. 1
they cost ~ 10.00 from the dealer.
Good luck !
post Jun 6, 2009 - 4:38 PM
97gt5sfe
Joined May 11, '09
From Las Vegas
QUOTE (Culpable04 @ Jun 1, 2009 - 9:05 PM) *
Good luck !
Thanks for the part number I really appreciate it. Posting the setup would be great, also if you can post a pic of the rotor too. I guess not a whole lot of people have put the GT4 rotors on the US spec celica, as it is a pain I suppose. I still wanna do mine even though they are a pain and because no one else has celica calipers -its kind of unique.
post Jun 6, 2009 - 8:27 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I haven't post the write up for lack of time, but I'll try to see if tomorrow I get the pictures for it. it's not a pain at all, as long as you have the right stuff.
for now take a look at this picture, it'll keep you entertain while I work on the full write up.
That's ST front brake system, next to ST205 calipers + custom rotors installed on USDM strut tower
post Jun 6, 2009 - 11:27 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
VERYYYY NICE SETUP!
330whp 309ft/lbs @ 21 PSI
post Jun 7, 2009 - 11:11 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Is the strut with the 205 conversion a Superstrut or std Mcphearson strut??
This post has been edited by jeffrosie: Jun 7, 2009 - 11:15 AM
post Jun 7, 2009 - 12:07 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (jeffrosie @ Jun 7, 2009 - 11:11 AM) *
Mcphearson strut
Pictures and details to come, hopefully later today.
post Jun 7, 2009 - 3:00 PM
jeffrosie
Joined Sep 11, '08
post Jun 7, 2009 - 3:30 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (Culpable04 @ Jun 6, 2009 - 9:27 PM) *
culp i hope when i come for dwg we can swap rotors... that way we can see if the will fit superstrut cause 500 for rotoes is not looking pretty lol
post Jun 7, 2009 - 5:25 PM
Culpable04
Joined Apr 17, '06
From New Jersey
this rotor will not fit on superstrut suspension, but I told you, I have another rotor that will. smile.gif
post Jun 7, 2009 - 6:24 PM
Culpable04
Joined Apr 17, '06
From New Jersey
READ and POST !
post Jun 12, 2009 - 4:13 AM
97gt5sfe
Joined May 11, '09
From Las Vegas
QUOTE (Culpable04 @ Jun 6, 2009 - 8:27 PM) *
Interesting shot showing the difference between the two. Just for clarification...are the ST knuckle and GT knuckle (U.S.) the same?
post Jun 12, 2009 - 9:44 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (97gt5sfe @ Jun 12, 2009 - 5:13 AM) *
Yes they are the same.
post Jun 14, 2009 - 4:09 PM
turbochloe
Joined Jul 22, '07
From nj
lol i like how u used jims truck as a table lol
Lo-Fi Version Time is now: January 7th, 2025 - 8:59 PM
