> How do you tighten up power windows or windows in general, windows seems loose and doesn't close all the way
post May 30, 2009 - 7:26 PM
chacha
Joined Dec 29, '05
From So-Cal
my windows seems to be loose on both driver and passenger sides...when i was at a toyota dealership, i told them of this problem....they suggested that i might need an adjustment and tightening of the window to solve the problem...I don't want to resort to them because it's an arm and a leg....i have searched the forum here and couldn't find any info about tightening the windows....any one with any suggestions or tips to do it correctly? checked online as well and nothing helpful. how do i make sure the windows are where they should be or if the window is even loose? the reason i say this is because the window can flex back and forth (rattling when i close the door) easily compare to new car doors when i close it....not a solid closing sound, hence the window rattles...hopefully that makes sense to someone. rolleyes.gif
This post has been edited by chacha: May 30, 2009 - 7:27 PM
post Jun 2, 2009 - 4:17 AM
AnaXyd
Joined Jul 15, '08
From Norway
I have also this problem. When I close my door with the window half down, it rattles like ****, and does not make any quality character.
post Jun 2, 2009 - 6:56 AM
enderswift
Joined Jul 12, '08
i also had this problem and it turned out to be an easy fix. simply take off the door panel and tighten a single nut at the bottom of the door. you cant miss it.
I have to go to my physics course now but ill take some pics of the inside of the door as the nut got loose and it rattles again. im gonna use some lock tight. hopefully it doesn't rain today
post Jun 2, 2009 - 4:39 PM
chacha
Joined Dec 29, '05
From So-Cal
that's what i needed...will this limit the wind coming in
post Jun 2, 2009 - 4:57 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
That's exactly what you need to do - enderswift is correct. Just make sure you don't overtighten the nuts because you could crack the window. There are 3 nuts you tighten IIRC. You'll know when you get the door panel off, there are service holes where each one screws on. You will likely have to put your window down part way to line the screws up with the service holes. To tighten them, you'll need a socket... I think it's a 10mm IIRC but it might be 14. If you don't have a deep socket that reaches, you may need an extension so you can reach the couple of inches in to the service hole to reach the lug nuts.
post Jun 2, 2009 - 8:30 PM
DEATH
Joined Dec 19, '07
From tx
I fcukin HATE that sound and look on such otherwise sexy car.
This post has been edited by DEATH: Jun 2, 2009 - 9:31 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 3, 2009 - 10:17 AM
AnaXyd
Joined Jul 15, '08
From Norway
Do somebody have a picture or a description where I can find this adjustment nut?
post Jun 3, 2009 - 3:45 PM
mikew04
Joined Feb 19, '04
From austin tx
Take off your door panel and roll your window up/down until you see the nuts; IIRC there should be holes in the sheet metal where they will line right up
post Jun 3, 2009 - 5:14 PM
AnaXyd
Joined Jul 15, '08
From Norway
post Jun 3, 2009 - 6:47 PM
wilc4
Joined Apr 14, '09
From Moreno Valley, CA
My rear passenger power window goes about 80% of the way up and then stops. I can then push the up button and pull up on the winder with my hand and it will go into place. Is this also my problem? Also, can anyone tell me how you remove the interior panel to get to the window? I have a Celica GT-S convertible.
Thanks!
post Jun 3, 2009 - 8:06 PM
chacha
Joined Dec 29, '05
From So-Cal
here are the pics....where are the bolts?
post Jun 4, 2009 - 3:40 PM
wilc4
Joined Apr 14, '09
I don't see any. I am glad you are doing this before me...
post Jun 5, 2009 - 8:44 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
QUOTE (chacha @ Jun 3, 2009 - 9:06 PM) *
Youll have to lower your window to reach some of the bolts through the maintenance holes. And likewise, raise it to reach other ones.
(\__/)
post Jun 5, 2009 - 12:08 PM
GriffGirl
Joined Feb 7, '07
Put your window down all the way first and you'll see them. I've circled the service holes for you. I'm pretty sure I've circled the right ones as I recall them, but I may be off. You can't miss it though once you've put the window down. Just do it and you'll see. This is SUPER easy.
QUOTE (AnaXyd @ Jun 3, 2009 - 3:14 PM) *
If I Remember (or recall) Correctly
post Jun 5, 2009 - 12:52 PM
AnaXyd
Joined Jul 15, '08
From Norway
The lowest ring is where the manually window crank thing is. Sure there are some adjustment screws behind that one? Because then I have to remove a lot of stuff.. tongue.gif
post Jun 5, 2009 - 4:08 PM
enderswift
Joined Jul 12, '08
when i did this... i just tightened the nut at the very bottom (behind that horizontal bracket). it solved all my noise issues until it got loose again. try that first and if it doesn't work out then go ahead and mess around with the adjustment screws everyone else suggested.
use locktite btw
post Jun 5, 2009 - 10:08 PM
chacha
Joined Dec 29, '05
From So-Cal
thanks to everyone whom contributed...i haven't tried yet because i have got so many things going on, but soon i will update.
This post has been edited by chacha: Jun 5, 2009 - 10:09 PM
Lo-Fi Version Time is now: November 25th, 2024 - 8:49 PM
