> air bag light is on
post Jun 4, 2009 - 8:50 PM
Superaison
Joined Apr 25, '09
From Ohio, USA
anyone help me diagnose this issue?
I still own my celica, but i'm parting it out and junking it.. Or selling as a whole. Have a honda prelude now :(
post Jun 5, 2009 - 1:02 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Have you tried using the search function on the site?
http://www.6gc.net/forums/index.php?act=Se...%2Bairbag+light
post Jun 5, 2009 - 2:23 PM
Superaison
Joined Apr 25, '09
From Ohio, USA
Yeah I did, they always had it to get the air bag light to just shut off. I actually want to fix the problem.
post Jun 5, 2009 - 2:47 PM
GriffGirl
Joined Feb 7, '07
If you read through some of the threads/posts, you'll see that the problem appears to be that either the sensors have gone bad and need to be replaced, or that the airbag(s) themselves need to be serviced. You'll also see in the posts that it suggest that you first check your fuse (or relay? I don't remember) to make sure it hasn't gone out. If the fuse/relay/whatever is good, the next step is to check the sensors as that is most likely the culprit.
post Jun 5, 2009 - 8:03 PM
Superaison
Joined Apr 25, '09
From Ohio, USA
idk where sensors are, also, For now, I yanked the fuse... I need it fixed because of my father is really anal about those kinda things.
post Jun 5, 2009 - 8:29 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
the sensor is under the center console. it is a metal rectangular box with a yellow cable going to it. you'll need a special screw driver head to get it out.
Lo-Fi Version Time is now: November 25th, 2024 - 10:57 PM
