> Drive Axel?, It's broken.. kinda
post Oct 18, 2003 - 12:53 PM
speedracer_2020
Joined Jun 22, '03
From Toronto, Ontario, Canada
So I've been hearing a rattling noise in the old Celica..
And recently a sudden loss of power when the car in gear (revs like a charm while not engaged)
But... when I took the car in for an oil change the mechanic noted that "A couple drive axels are busted"
Not to be stupid (I know what they do.. but I need an explanation for my car's power loss): What are the purpose of these? .. and when damaged will there be any noticeable poewr loss when driving. The car still drives. Only rattles under high acceleration under 50km/h...
Lemme know.. thanks
Shaun
post Oct 18, 2003 - 1:41 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
sounds more like a CV problem. If they are gone, it is not to bad a fix, just get remanufactured axels form Partsource or somebody like that. Don't get from Toyota, they are an arm, leg and left testicle.
Is it a uniform loss of power, or intermittant?
Does the power loss conincide with any weather condidtions?
btw: you were looking for places to buy a 3SGTE right? I have found a few places in Canada that supply them if you are interested.
post Oct 18, 2003 - 6:12 PM
AJcelica
Joined Sep 13, '02
From BC, Canada
QUOTE (GeEkBoY @ Oct 18, 2003 - 11:41 AM)
post Oct 19, 2003 - 1:40 PM
GeEkBoY
Joined May 17, '03
I am not necessarily recommending any of these places, nor have I spoke with any of them. I came across them merely through internet searches.
Toronto:
http://www.a1jdmengines.com/home.htm
http://www.unitedmotionsupply.com/
Toronto and Vancouver:
http://www.jkjapaneseengines.com/page2.html
Quebec somewhere:
http://jspecautosports.com/
http://www.osakajdmmotors.com/contact/index.html
not sure where this one is, but I think it is Toronto or Montreal:
http://streetimports.com/homepage.htm
if anyone has any feedback on these companies, please post.
post Oct 19, 2003 - 3:46 PM
AE101
Joined Sep 12, '03
From NB Canada
Lemme know.. thanks
Shaun
where are the drive axles busted? if the CV joint is worn out, you should be hearing a clunking noise when going around turns. If it's busted then you would not be able to drive the car at all.
how many km's on your car? is it auto or 5spd?
if it's a rattle you hear, under the hood it may be a broken engine mount.
as for the power loss, from the info given I have no idea what to tell you, except take it to a shop you trust.
post Oct 21, 2003 - 11:40 AM
97GTinKC
From KC
Could the "rattle" be pinging from low grade fuel or a timing problem? might help explain the corresponding lack of power?
Also the mechanic may have meant the axle boots are bad, not the axle itself. You can change the boots yourself with basic tools, but is is a fair amount of work, and messy, (you need to flush all the grease out and inspect the balls and races for pitting or wear grooves, if everything looks good, re-assemble with new boots and grease, otherwise consider new joints or axle assemblys.
As for the "remanufactured" axles, I would stay away from them, I tried some on another car, had to warranty the right side 3 times within 2 years, (but I got really fast at changing them!), seems all most of these companies do is wash them out, drop new balls on the worn races and stick new boots on. Finally had them get me some NEW ones and no more problems. MOOG was the only company I knew of that actually re-machined the races and used oversized balls, not sure they are still doing CV axles, probably couldn't compete pricewise with all these others...
Lo-Fi Version Time is now: November 30th, 2024 - 8:00 PM
