Oil light on when I start up, Fresh oil change |
Jun 12, 2009 - 6:44 PM |
Enthusiast Joined Jan 29, '08 From Abbotsford Currently Offline Reputation: 4 (100%) |
Hey guys I just have a quick question. I've just done a fresh oil change about 2 weeks ago and since then when my car is cold just for a second or two max when I start it up my check oil light is on and I can hear a slight knock underneath the hood.
I've consistently checked my oil since the change hot and cold engine and its around the middle to the dip stick of not a bit higher. I've checked for any leaks on my filter and nut on the pan but they're both good. Thanks in advance! I'm off to work so it will be a while for my responses. |
Jun 14, 2009 - 8:31 AM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Whenever I start mine up first thing, the oil light comes on for a sec or 2 (just like you said) and then it turns off. Also, I see the same thing happening with my mechanical oil pressure gauge as well. When I turn it on, a sec or 2 passes and then the oil press needle raises up to 60 psi. I don't have any other oil related issues, in fact my celica runs very strong.
I think it's normal. I'm curious now to see what other members write on this? This post has been edited by 6G96GT: Jun 14, 2009 - 8:32 AM |
Jun 14, 2009 - 8:59 AM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
Whenever I start mine up first thing, the oil light comes on for a sec or 2 (just like you said) and then it turns off.I think it's normal. I'm curious now to see what other members write on this? That is normal, the knocking is not. Rod bearings are worn and probably need replaced -- just my .02 --any chance you could record the sound for us? |
Jun 14, 2009 - 3:38 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Maybe the sound you're hearing is the valves clattering before they get oiled? I know mine starts and puts the oil light on for just a second or two, and the valves are noisy because they haven't received the pumped oil yet.
-------------------- 1999 Celica GT
Jun 14, 2009 - 11:47 PM |
Maybe the sound you're hearing is the valves clattering before they get oiled? I know mine starts and puts the oil light on for just a second or two, and the valves are noisy because they haven't received the pumped oil yet. This is what I'm thinking, hoping its valves and not a rod knock. I'll try to get a recording up fairly soon just gotta find my camera. |
Jun 17, 2009 - 11:59 AM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
Very cheap or defective oil filters can cause this.
Jun 18, 2009 - 11:13 AM |
Very cheap or defective oil filters can cause this. Maybe the sound you're hearing is the valves clattering before they get oiled? I know mine starts and puts the oil light on for just a second or two, and the valves are noisy because they haven't received the pumped oil yet. This is what I'm thinking, hoping its valves and not a rod knock. I'll try to get a recording up fairly soon just gotta find my camera. There has to be more to it then that or I wouldn't be shelling out the money for Wix filters. -------------------- 1999 Celica GT
Jun 19, 2009 - 5:23 PM |
The oil light coming on means the oil pressure is low. If you KNOW you have enough oil in, and you've done everything right, the first thing I'd be concerned about is that your oil pump is failing.
Jun 23, 2009 - 8:02 PM |
So...if my light comes on for 2-3 seconds every time I start it but then goes away the rest of the driving time, can I expect any damage for just that mere 2-3 seconds of it being on say over a period of 2-3 months or more?
Lo-Fi Version | Time is now: January 10th, 2025 - 12:01 AM |
