> where can find this bulb ?, change to bule led
post Jun 13, 2009 - 3:18 AM
Neil_Y
Joined Dec 8, '08
From Australia/Hong Kong
from the AC control panel,i want change to blue led
This post has been edited by Neil_Y: Jun 13, 2009 - 4:25 AM
post Jun 13, 2009 - 3:40 PM
Neil_Y
Joined Dec 8, '08
bump.. no one knows ??
post Jun 14, 2009 - 1:08 AM
Neil_Y
Joined Dec 8, '08
bump.. anyone help me ?
post Jun 14, 2009 - 1:20 AM
Neil_Y
Joined Dec 8, '08
post Jun 14, 2009 - 1:41 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
that is a 194 bulb, generic Automotive bulb, but if u wana change your CC panel to blue i would talk to bmj its not as easy as swapping the bulb you need to modify the panel for correct output. (soldering resistors)
post Jun 14, 2009 - 1:49 AM
Neil_Y
Joined Dec 8, '08
post Jun 14, 2009 - 2:24 AM
Celiquick
Joined Feb 6, '09
From Lexington, KY
Try finding some refractor/refraction LEDs that point in 5 directions. I have some white ones in my dash to compliment my indiglo gauges. They're just plug 'n' play. They're also pretty inexpensive on eBay.
Celiquick
'97 Celica ST "Really" Limited Edition
"I thought you always wanted an all-wheel drive, turbo-charged, Evo-eating machine sitting in your backyard.....who wouldn't?!?"
Celica FS/Part-out
post Jun 14, 2009 - 2:36 AM
Neil_Y
Joined Dec 8, '08
is it T3 led??
http://cgi.ebay.com.au/2pcs-T3-T4-T5-Neo-W...93%3A1|294%3A50
post Jun 14, 2009 - 10:24 AM
Neil_Y
Joined Dec 8, '08
bump.
post Jun 15, 2009 - 7:57 AM
Neil_Y
Joined Dec 8, '08
QUOTE (Neil_Y @ Jun 14, 2009 - 3:36 PM) *
bump..
post Jun 16, 2009 - 3:19 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I don't think that's a 194 bulb, I think it's a 74 bulb. I can't remember. But it seems that the CC bulb is smaller than the bulb that goes in the instrument cluster, which I know to be a 194. I'm pretty sure the climate control (and ash tray light, cigarette lighter ring) is a 74.
You can get LED replacement bulbs here.
post Jun 17, 2009 - 12:24 AM
Neil_Y
Joined Dec 8, '08
just what to change the cc panel to blue color..but i haven't thought it's made me vexed.
post Jun 19, 2009 - 1:21 PM
GriffGirl
Joined Feb 7, '07
So buy those bulbs I linked you to, and buy LEDs to solder in to where your climate control currently has green LEDs. (Those bulbs must be soldered in)
post Jun 24, 2009 - 8:02 AM
r1chie
Joined May 14, '09
From Sydney, NSW
Been meaning to do this too and i was researching this forum and found other ppl who didnt solder in leds and kept it simple and put in bulbs (plug and play). check out these discussions
http://www.6gc.net/forums/index.php?showtopic=56078
http://www.6gc.net/forums/index.php?showtopic=61249 -
>"How-To: Back Lighting: Other Options
There are also 10mm "neo wedge" bulbs here, which *could* even be a perfect fit. A while back i found specs on the toyota bulbs that said they were 9.5mm. I have *NOT* tried the 10mm neo wedge yet." Zimluura
i found alot of ppl recommended superbrightleds.com . they sell normal 194 and 74 leds with resistors inside but i not sure abt the neo wedge bulbs ur looking for but they do sell a variety. best bet is to look at the dimensions of the oem bulb and find the correct fit and look on sbl. its confusing on here every1 saying get different sizes. id recommend buying leds from them, i bought some from them and ebay and sbl quality is by far better. let me know how u go and if u can clarify the dimensions thatd be sweet coz i too want to do this biggrin.gif
post Jun 26, 2009 - 12:31 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
there is NO direct replacement bulb for the Climate controls... there are a few bulbs that fit but NONE will give you even close to good lighting... only half the buttons will light up... no dial indicators... and no A/C light... only custom job can give you the lighting found in some members pictures
Breaking Axles...
post Jun 6, 2011 - 9:38 AM
scootch
Joined Jun 6, '11
From bulldog1
QUOTE (Neil_Y @ Jun 13, 2009 - 4:18 AM) *
First you HAVE to determine what bulb type you are replacing. Alot of the older #168 or 194 are called T-10 for LEDS. Best place I found was on E-Bay BUT go throgh ALL the pages FIRST !!! ( I bought 10 T-10[194] ) bulbs there, though they came from china for .25cents plus @2.85 for shipping. All worked and alot better than paying @ $7-8 bucks for one !!! (check the sylvania bulb guide for more help determining your bulb) Good luck and hope this helps.I learned this the hard way.
post Jun 6, 2011 - 9:45 AM
scootch
Joined Jun 6, '11
From bulldog1
I forgot to tell ya, they have the dropping resistor in them so if it's a wedge bulb, it's plug in and enjoy, but rember that LEDs are directional to power, can't hurt if put in backwards, just remove and reinstall 180 degrees
Lo-Fi Version Time is now: February 17th, 2025 - 10:51 AM
