> clutch pedal, wont return????
post Jun 17, 2009 - 5:32 PM
pipes
Joined Apr 23, '08
From boston MA
hey guys my pedal is having a tough time returning...i checked for leaks there are none and it will only do it with the car on if the car is off it works perfect
post Jun 18, 2009 - 8:03 AM
pipes
Joined Apr 23, '08
From boston MA
bump now it doesnt return
post Jun 18, 2009 - 8:12 AM
its either the master or the slave.
if you pump the pedal and hold it down, and the slave comes out and slowly goes back in, the slave is bad. if the slave dont move at all, the master is bad.
post Jun 18, 2009 - 8:20 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
QUOTE (presure2 @ Jun 18, 2009 - 9:12 AM) *
post Jun 18, 2009 - 8:36 AM
pipes
Joined Apr 23, '08
From boston MA
ok thanks man gotta check yhat
post Jun 18, 2009 - 9:30 AM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (pipes @ Jun 18, 2009 - 9:36 AM) *
well now my next problem would be getting these parts......cause they are not local
post Jun 19, 2009 - 12:58 PM
pipes
Joined Apr 23, '08
From boston MA
ok good news guys for those who care... i rebuilt my clutch master car is back on the road again
post Jun 19, 2009 - 1:21 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
post Jun 23, 2009 - 6:35 AM
ksporry
Joined Mar 14, '09
From Portishead
I was gonna say, pipe leak. I had that with a Passat once. If the rebuild worked for you, that's great news!
post Jun 23, 2009 - 6:45 AM
Sweet deal...I think I have the closest replacement for your master cylinder and you aren't getting mine laugh.gif
what did you rebuild it with?
post Jun 23, 2009 - 8:10 AM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (playr158 @ Jun 23, 2009 - 7:45 AM) *
toyota has a rebuild kit with new spring seals and clips
post Oct 19, 2009 - 1:02 AM
azian_advanced
Joined Apr 18, '05
From Calgary
bringing this back up. my clutch pedal occasionally gets stuck while at a stop and sometimes when i accelerate while letting go of the clutch pedal, the pedal gets sucked back in on its own so I imagine one or both of my clutch cylinders need to be replaced or fixed. i want to rebuild my clutch cylinders on my own instead of purchasing an entirely new cylinder assembly. can you post the part number for the rebuild kit as I can't seem to find it on toyodiy. thanks.
post Oct 20, 2009 - 5:15 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (azian_advanced @ Oct 19, 2009 - 2:02 AM) *
sorry i took so long its not hard to rebuild 20 mins tops.... http://www.toyodiy.com/parts/p_J_1995_TOYO...BLMVZ_3103.html
post Oct 20, 2009 - 7:18 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
I cant' seem to get my Celi into gear. The clutch pedal goes down and comes back up ok, but it feels REALLY loose.
Ideas?
post Oct 20, 2009 - 8:08 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (pipes @ Oct 20, 2009 - 5:15 PM) *
Should I get all 3?
04311 CYLINDER KIT, CLUTCH MASTER
04311-12080 ST20*..MTM 1 $42.57
04311-12110 ST20*..MTM 1 $38.62
04311-60150 ST20*..MTM 1 $35.69
post Oct 20, 2009 - 9:39 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (azian_advanced @ Oct 20, 2009 - 9:08 PM) *
Should I get all 3?
no im sorry they will all work just cant remember wich one iklkl check at work 2morrow.....if anything ask them wich one is 20.50 if you weere an employee and thats the one you need
post Oct 21, 2009 - 9:04 AM
KAOS
Joined Apr 18, '06
QUOTE (azian_advanced @ Oct 20, 2009 - 7:08 PM) *
Should I get all 3?
Gerard; do you have an ST205? those parts that he linked us to were for the 205 chassis. The parts for the 204 are significantly different in price...
post Oct 21, 2009 - 9:22 AM
KAOS
Joined Apr 18, '06
QUOTE (presure2 @ Jun 18, 2009 - 7:12 AM) *
What if the pedal goes in and comes back out, but I cannot feel the clutch engage?
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 9th, 2025 - 1:16 AM
