> Gen 6 Not Starting, Think immobiliser!!
post Jun 19, 2009 - 2:41 PM
nathy_t
Joined Jun 19, '09
From Northants,UK
Hi there,
any help with this problem would be very much appreciated.
My celica sr just won't start! the strangest part is about 3 hour prior the car was working perfectly!
I put my key in and first and second click work fine (all dash lights come on, radio and clock working) the when i go to the 3rd click to turn the engine over the whole car cuts out and disconnects from all electrics, then had to wait for it to come back and same problem again. so thought maybe battery had died so went for jump start which brought the electrics back but once again when i go to start the engine just totally cuts out. when it cuts out everything goes, ive tried all 3 keys i have and the same problem for all 3! im totally lost. ive currently disconnected the battery hoping it might reset the immobilising system.
any help would be great thanks,
nathan
post Jun 19, 2009 - 3:44 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Sounds like a short somewhere, or something is seriouslly draining the electrical system.
Check all fuses first, see if any are popped.
This post has been edited by rave2n: Jun 19, 2009 - 3:45 PM
post Jun 19, 2009 - 9:21 PM
luka
Joined Jul 23, '08
From Hawaii
also check your battery connections.
post Jun 20, 2009 - 7:16 AM
rave2n
Joined May 29, '09
Its all about surface area on the battery terminal, if its lose and been arcing over onto the post, there is going to be carbon build up. You'll need to clean the connection and the post with a wire brush. Had this happen one time one a stratus when I forgot to tighter it back up biggrin.gif
post Jun 20, 2009 - 2:05 PM
azian_advanced
Joined Apr 18, '05
From Calgary
check if your starter is getting a power signal from the ignition while trying to start the car. if there's no power maybe your ignition barrel is broken. if there is, check your starter connections, but if it's all good, replace your starter.
Lo-Fi Version Time is now: January 12th, 2025 - 2:55 AM
