'95st + '91 3sgte = ?exhaust, what fits? |
Jun 21, 2009 - 7:46 PM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
SOoOo i'm swapping a '91 3sgte into a '95 st, and i want to know what exhausts will fit... can i fit a gt4/st205 exhaust? do i have to fit an st202/at200 exhaust? if so what kind of losses will there be? (power/quality) please let me know, thanks guys/gals.
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jun 21, 2009 - 11:33 PM |
neither.
you will need to have an exhaust shop make a new exhaust for you. 3inch is recommended. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 22, 2009 - 11:37 AM |
neither. you will need to have an exhaust shop make a new exhaust for you. 3inch is recommended. dammit anyone mind explaining why this is? thank you. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
Jun 22, 2009 - 1:31 PM |
its a different engine. the downpipe is in a different position than your st headers, and the factory st exhaust is too small for a turbo car.
if this is a huge problem, than your not going to like all the rest of the stuff you need to do to finish your swap. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 22, 2009 - 2:11 PM |
Enthusiast Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
its a different engine. the downpipe is in a different position than your st headers, and the factory st exhaust is too small for a turbo car. if this is a huge problem, than your not going to like all the rest of the stuff you need to do to finish your swap. haha i agree with lagos..if its a big problem then i say you shouldnt attemp the swap..the exhaust isnt even the least of your problems. -------------------- |
Jun 22, 2009 - 3:00 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
st headers Header... yea...did you start the swap yet? just read all the info you can..the st swap is the biggest pain in the @ss....if your not to connected with your car, i would suggest trying to sell it and pick up a gt with a blown motor, or a shell, with the trans, axles, and what not...its much easier...it CAN be done...it just takes a little more work then the GT -------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jul 16, 2009 - 2:24 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
Take the 7afe out,then drop the 7afe exhaust,then put in the 3sgte,bring it to an exhaust shop and they will make u a 3" exhaust for roughly 300$
-------------------- BANNED. for life, you moron.
Jul 16, 2009 - 2:56 PM |
really dont need 3" 2 1/2 or 2 3/4 will be fine
Jul 17, 2009 - 4:06 AM |
Enthusiast Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
really dont need 3" 2 1/2 or 2 3/4 will be fine define be fine?? if you mean its going to run... then yes... is it going to give all the performance it can? no... bigger exhaust on a turbo is always better... perfect would be no downpipe at all... straight out exhaust turbo housing... but now you are getting into idle issues... some guys run 4"... some 2 1/2... as stated in the very first few posts... 3" is recommended... best of both worlds... smooth idle and good for reducing turbo backpressure... -------------------- Breaking Axles...
Jul 18, 2009 - 12:48 AM |
Enthusiast Joined Oct 10, '08 From sweet home, OR Currently Offline Reputation: 3 (100%) |
a 4" tip looks ridiculous lol
Jul 18, 2009 - 12:53 AM |
a 4" tip looks ridiculous lol forget tip.. ive seen 4" pipe ran the entire way... -------------------- Breaking Axles...
Jul 18, 2009 - 8:11 AM |
on a 3s, a 3" exhaust will make more power than a 2.5 or 2.75" exhaust, even with minor mods.
dyno proven over on mr2oc. most aftermarket mufflers you see with a 3" inlet will have at least a 3.75-4" tip. IIRC defgeph's tip is 4.75"..i double dog dare you to tell HIM it looks rediculous. lmao -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: December 2nd, 2024 - 11:45 PM |
