Enthusiast Joined Dec 7, '08 From Trumbull CTGReen Currently Offline Reputation: 0 (0%) ![]() |
SOLD_SOLD_SOLD
1996 Celica GT Convertible, 192,xxx miles. Red with black top/ black leather interior. Has been owned since 21,500 miles. Purchased from a Team Toyota in 1998. Manual transmission, engine still runs well. Just replaced original clutch (after 190k) - so be sure that it wasn't driven hard. Interior/exterior both in decent shape, in all honesty it looks pretty good for a 13 year old car (IMHO) and runs like a younger car. Age issues: the electric/automatic roof does not work (need to take it down/up manually), no A/C (heat does work), CD changer does not work (radio/cassette player do), rear passenger window locked in up position-off the track, power antennae needs new mast (motor works). I've always changed oil regularly and driven it carefully. No accidents. Write me with any questions, I'll give you the honest answers. Bottom Line---It is a fun car with no known major issues. You know the bad now the good: Rear window glass replaced +,- $500 Both front axles replaced @ 100,704k $537. Radiator, replace all pulleys and tensioner, timing belt kit, water pump, thermostat & gasket, replaced temperature sensor for cooling fans, oil change @ +,- 150,330k $1424 Front brakes and 2 new tires +,- 178,212k $490 Valve cover gasket, oil pump kit,timing belt,valve cover gasket, p/s belt, alt/AC belt, water pump, front oil pump gasket kit, oil changr, battery +,- 183,584k $1119 New clutch assembly 189,157k $873 Oil change +,- 190k New wires, plugs, rotor and rotor cap replaced @ +,- 191k KBB in fair condition $3950 Asking $3500 Car is in Trumbull CT and used regularly. Pictures at http://s287.photobucket.com/albums/ll135/Ron526/ This post has been edited by Ron526: Jun 28, 2009 - 9:56 AM |
Lo-Fi Version | Time is now: April 22nd, 2025 - 10:19 PM |
