> does a 3rd gen 3sgte use a FMIC or does it have top mount IC?
post Jun 25, 2009 - 1:52 AM
silverceli09
Joined Nov 13, '08
From Indiana
just lookin around at some 3s swap stuff and i am curious, does the 3rd gen use an FMIC or is it stock top mount?
Celica Or Die, check out http://www.redlinemotive.com!
post Jun 25, 2009 - 2:18 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (silverceli09 @ Jun 25, 2009 - 2:52 AM) *
stock top mount
post Jun 25, 2009 - 2:23 AM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (Mstoochn @ Jun 25, 2009 - 2:18 AM) *
stock top mount
i finally found a good pic of one and it looks as if the IC is mounted on the side verses the top. would running a FMIC do anything more power wise?
post Jun 25, 2009 - 2:37 AM
Mstoochn
Joined Apr 27, '09
QUOTE (silverceli09 @ Jun 25, 2009 - 2:23 AM) *
stock top mount
Not to my knowledge, i would talk to _jim_. hes using a stock WRC gen3 top mount intercooler and he is aiming to make more power than anyone on these forums (400+whp)
Top mount as shown -> http://www.frontlineengines.com/engines/cc...Main_18_118.jpg
you may have been looking at MR2 3s-gte
This post has been edited by Mstoochn: Jun 25, 2009 - 2:39 AM
post Jun 25, 2009 - 7:36 AM
just to clarify a bit.
the 3rd gen uses a top mount water to air intercooler, which uses coolant to the intake air VS a 2nd gen air to air top mount that used air that is forced over it by the scoop on the alltrac hood.
the water to air intercooler is much more efficent than the 2nd gen or most FMIC's you see on ebay.
also, tufy, hardtarget and a few others here, as well as dozens over on mr2oc have been making 400whp+ on the 3s for years.
post Jun 25, 2009 - 10:42 AM
silverceli09
Joined Nov 13, '08
From Indiana
will a mr2 3s mount just the same as one from a celica?
post Jun 25, 2009 - 11:00 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
QUOTE (silverceli09 @ Jun 25, 2009 - 10:42 AM) *
????? but no the stock mr2 ic wont fit any of the celicas. the celica ic are all top mounted...all the mr2 ic are all side mounted...but u can use a celica st205 water cooled ic on a mr2 with little mods.
post Jun 25, 2009 - 11:06 AM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (RUNNIN-LOW @ Jun 25, 2009 - 11:00 AM) *
no no...not just the intercooler, i was wondering if a whole 3sgte from an mr2 will mount up in a celica
post Jun 25, 2009 - 11:52 AM
QUOTE (silverceli09 @ Jun 25, 2009 - 11:06 AM) *
the motor itself, yes. but there are diffrences.
the mr2 mounts the alternator on the back on the motor, the water necks are diffrent, harness ect. you need to use celica parts to make it all work in a celica.
Lo-Fi Version Time is now: January 10th, 2025 - 9:31 AM
