Enthusiast ![]() ![]() Joined Dec 13, '03 From Alabama Currently Offline Reputation: 1 (100%) ![]() |
Since you can't search for st in the search box and I've looked everywhere else. What combination of parts do you need to have a/c with a 3sge swap in an st? I know you can use the GT compressor with a 3s and I also know that the GT and ST compressors have different part numbers. I'm also wondering which lines you would use. Has anyone done this?
Since you can't search for st in the search box and I've looked everywhere else. What combination of parts do you need to have a/c with a 3sge swap in an st? I know you can use the GT compressor with a 3s and I also know that the GT and ST compressors have different part numbers. I'm also wondering which lines you would use. Has anyone done this? all GT parts. -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) ![]() |
Hmm good to know, got the 3g swap coming up at the beginning of the year, was wondering if there was more to it.
Enthusiast ![]() Joined Dec 30, '08 Currently Offline Reputation: 4 (100%) ![]() |
I have an ST with a 3sgte. I got everything i needed off a GT in the junkyard
OK thanks guys. I had a feeling that would be the case.
Lo-Fi Version | Time is now: February 16th, 2025 - 3:51 PM |
