2 Pages V  < 1 2
> e-153 tranny
post Oct 22, 2003 - 7:26 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (1900 @ Oct 22, 2003 - 3:22 PM)
if u can afford it get an st-205 from clip, u will need is the diff from an mr2 turbo gearbox to make the gt4 gearbox fwd and half shafts from the mr2 turbo and u will have to get custom axles made. every thing else u will need the front clip will provide.
Custom axles are not necessary.
post Oct 23, 2003 - 2:09 AM
kdash
Joined Sep 17, '03
From lakewood, ca
so.....i should get the clip for the st185. i got the tranny of a mr2 turbo and i'm about to get a front clip for the st185. what else is needed for my swap to be complete? what i said earlier to you i apologize i was just stress out at the time. thanks. i am sooo close to starting it i want to start it right away. let me know when you get the chance. and remember i want to keep mines as fwd.
post Oct 23, 2003 - 2:22 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
no matter what it will be FWD, the only way to make it AWD is very expensive, so no one will give you any advice on how to make it anything other then FWD.
Whats different about the solara tranny, and did someone say that the 3s-ge tranny is an e-153?
post Oct 23, 2003 - 2:24 AM
Jabberwock
Joined Sep 22, '03
Like I said before
You will need a custom exhaust
Maybe a custom intake for the AFM..?
Probably a Full Tune UP
FMIC is recommended, unless you are going to install a scoop
There are a lot more little things you need so you should do a search and you will find it easily since this swap is constantly talked about.
post Oct 23, 2003 - 10:15 AM
kuya1284
Joined Nov 15, '02
QUOTE (kdash @ Oct 23, 2003 - 12:09 AM)
... and like I said before ...
post Oct 23, 2003 - 8:08 PM
Joined Jan 27, '03
From st.lucia
the st185 axles are too short for the st-205 so i had custom axles made unless the axles off the v6 camrys fit. let me know what u used.
post Jan 8, 2004 - 12:30 AM
AJcelica
Joined Sep 13, '02
From BC, Canada
QUOTE (kuya1284 @ Oct 20, 2003 - 4:44 PM)
QUOTE (kdash @ Oct 20, 2003 - 4:36 PM)
ok i know now that i need the e-153 tranny in order for the 3sgte engine to run smoothly and allow everything to work fine and not blow anything up.  my question is how much would it cost me if i was to go to toyota and ask them for one?  what year should i get for this v6 camry tranny?  all i need is this in order to start my 3sgte swap.  I'm really excited to start on it but this is the only thing holding me back.  can't wait  biggrin.gif
If you want to get an accurate price, you may want to try calling the parts department at Toyota...
When I called one locally, I was quoted around $1500 just for the (brand new) tranny...
is that a brand new tranny with or without LSD? without right?
post Jan 8, 2004 - 12:56 PM
kuya1284
Joined Nov 15, '02
QUOTE (AJcelica @ Jan 7, 2004 - 10:30 PM)
It was with LSD. The one without LSD was around $1100.
post Jan 8, 2004 - 2:40 PM
AJcelica
Joined Sep 13, '02
From BC, Canada
QUOTE (kuya1284 @ Jan 8, 2004 - 10:56 AM)
good to know!
thanks.
2 Pages V  < 1 2
Lo-Fi Version Time is now: January 11th, 2025 - 4:07 AM
